Hi Stefan,
I have most of the parts in place now for the component to setup the sensor and read the raw data back. I've got a few more bits to add and testing to do, just need to find another hour to sit down with it again. Do you have a sensor there so you can help me test it?
MAX30100 component
- Has thanked: 634 times
- Been thanked: 840 times
Re: MAX30100 component
- Has thanked: 245 times
- Been thanked: 257 times
Yes, I have a Sensor here, connected to a ESP32 Board and FC10 Beta running.
And time to test.
And time to test.
Hi Jorgen,
Yes I'll try and get this one over the line today.
- canary_wharfe
- Has thanked: 15 times
- Been thanked: 16 times
Thanks Ben
Really appreciate the effort. Hopefully another big step forward in the Flowcode component arsenal.
< The Flowcode 11 Pro Silicon Chipper >
I've pushed a fairly simple version to the v9/v10 update systems now.
I hope to do more testing in future and also generate some examples to show monitoring heart rate and blood oxygen levels.
Basic program should include.
Initialise()
Loop Forever
Count = Update()
Loop Count times
Red = ReadRed()
IR = ReadIR()
Loop Count End
Loop Forever EndRegards Ben Rowland - MatrixTSL
On FC10 it's not working. I can not set the red ligth on or read a signal.
The same on FC9
On FC9 it's not working. I can not set the red ligth on or read a signal.
I use a ESP32
The same on FC9
I use a ESP32
