which post has the code are you referring to:
Post 1 @ Sun May 08, 2022 3:04 pm
or post 2 Mon May 09, 2022 12:28 pm
Light Sensor
- Has thanked: 796 times
- Been thanked: 858 times
Re: Light Sensor
That code was a quick way to test on hardware only.
even though the simulation only shows 1 LED, it will work with all 8 on hardware.
For both hardware and simulation, the Count within led_array properties should be changed from 1 to 8.
I have done that on the attached Flowchart.
Instead of the light sensor component, a Potentiometer can be used.
the LED array was used as that was already connected.
Alternatively, the value can be sent to an LCD if you have one.
- Flowcode LDR test sim and hardware.fcfx
- (10.23 KiB) Downloaded 483 times
- (view online)
