That component was created by one of our users, the link to the component can be found towards the end of the wiki page. It might be worth downloading and trying their component to see if that works any better.
Here is the wiki page for our component which is the one you're currently using in the project.
https://www.flowcode.co.uk/wiki/index.p ... _(Storage)
I wonder if it's worth simplifying and maybe trying to write and read a few different addresses and seeing what happens. The device can only write two locations at once and so it might be good to see if it's consequtive addresses that are failing.
I also found that the configuration bits to set the flash security are missing from the configuration screen. however checking these it looks like the defaults should allow full reads and writes.
FlashEEPROM component emulate EEPROM
- Has thanked: 634 times
- Been thanked: 842 times
Re: FlashEEPROM component emulate EEPROM
