S_VE
- Has thanked: 56 times
- Been thanked: 4 times
Post
by S_VE »
medelec35 wrote: ↑Sat Jan 23, 2021 2:29 pm
for example, you can use
You can clear bits with cr_bit instead of st_bit.
So to enable weak pull-ups on PIC16F1825 for example, you can use
or
Hi Martin,
thank you for the useful info
Where can we get the details about these commands like
cr_bit( ) { for clear bit } , st_bit( ) {for set bit}, etc....
S_V
- Has thanked: 778 times
- Been thanked: 839 times
Post
by medelec35 »
You can see them within internals.c
Which can be found at the following for Flowcode10::
%ProgramData%\MatrixTSL\FlowcodeV10\CAL
FlowcodeV9:
%ProgramData%\MatrixTSL\FlowcodeV9\CAL
Since the directory is hidden, just copy and paste the above path in windows explorer.
S_VE
Post
by S_VE »
Thank you Martin.
-S_V
S_V
Post
by medelec35 »
You're welcome.
I have added the path for FC9 as well
