Hi Wayne.
I have used the 4.1 release version.
ESP32 + Potentiometer (fail to be compile)
- Has thanked: 698 times
- Been thanked: 768 times
- Has thanked: 427 times
- Been thanked: 647 times
Re: ESP32 + Potentiometer (fail to be compile)
As per previous post on subject, when I tested using my laptop, I was running IDF4.2 and Python 3.8.
I might have a copy of 4.1 but would need to check later
wayne_millard
- Has thanked: 1 time
- Been thanked: 9 times
I'll have a look for it later today, in the meantime, and I know it's a pain, have your tried:-
Uninstall all ESP / Git / Python and manually deleting any folders
Run registry cleaner
Reboot
Download and install as per guide but using 4.2 (install everything as administrator)
The above worked for me.
However it looks like you can get 4.1.4 from here https://dl.espressif.com/dl/esp-idf/
I'd still recommend you uninstall any previous first as per above.
As you are running FCv10 perhaps this may work to install v5?
viewtopic.php?f=3&t=1922
EDIT...
The espressif link also provides option to download 4.1.2 and 4.1.3 so you should be able to find something.
Reboot
EDIT...
