You should be able to download components without purchasing Flowcode.
The easiest way is to select the component you are interested in then select help.
If there are any components where the links are broken then please let us know.
Source Code
- Has thanked: 724 times
- Been thanked: 783 times
b.sgammato
- Been thanked: 2 times
Re: Source Code
Hi Martin
I can't download any components
I always get the page with 404 error
of which I attach screenshots
- Error.jpg (42.66 KiB) Viewed 2762 times
Re: Source Code
It could be that the internal browser internet connection is being blocked by a firewall?
What you can try is Select File>Global Settings
Make sure within the Application tab Web access is enabled.
Also, try enabling Show help in external browser.
After selecting OK, Reload Flowcode and try again.
Alternatively, you can select the component you are interested in via the Wiki components selection
b.sgammato
Re: Source Code
Hi Martin
I checked the settings and they are correct, but unfortunately I still get the same error.
Even with the link the result is always the same and I don't understand
Re: Source Code
Ah, right.
I have just checked and sorry to say there is an issue with the links.
Thank you for brining it to our attention, we will fix the issue and let you know when its all fixed.
b.sgammato
