Erasing text on graphic LCD
jandidden
Has thanked: 28 times
Been thanked: 12 times
Re: Erasing text on graphic LCD
Post by jandidden »
mnfisher wrote:
Tue Jun 13, 2023 9:44 am
It is possible to buffer the display I did it for a demo here viewtopic.php?f=10&t=1569&p=9135&hilit=Cheeting#p9135
However you need to use less bit depth- - I used 2,4 and 8 bit versions to fit in the available memory (on esp32)
You could use a similar technique to buffer part of the display.
Thanks Martin, I had looked at that some time ago but not sure I'm smart enough to pull it off.
I will look at it again - I learned a lot these last few months ;-)
Jan
Has thanked: 163 times
Been thanked: 960 times
Post by mnfisher »
The other thing to try is using the high speed SPI connection. See Ben's post at viewtopic.php?f=3&t=1851&p=10913&hilit= ... ben#p10913
Use the 'Window' command to just redraw the part of the display that has changed.
