PIC16 toolchain for FC9
Xbiotec
Has thanked: 37 times
Been thanked: 27 times
Re: PIC16 toolchain for FC9
Post by Xbiotec »
hi Medeled,
Do you know how to change WDTPS (postscaler) in C code?
I tried many differentes syntax but not lucky !
It's for a PIC24JF256A705
_FWDT( OPT1_ON & OPT2_OFF & OPT3_PLL )
** Watchdog Timer Postscaler bits:
** WDTPS_PS1 1:1
** WDTPS_PS2 1:2
** WDTPS_PS4 1:4
** WDTPS_PS8 1:8
** WDTPS_PS16 1:16
** WDTPS_PS32 1:32
** WDTPS_PS64 1:64
** WDTPS_PS128 1:128
** WDTPS_PS256 1:256
** WDTPS_PS512 1:512
** WDTPS_PS1024 1:1,024
** WDTPS_PS2048 1:2,048
** WDTPS_PS4096 1:4,096
** WDTPS_PS8192 1:8,192
** WDTPS_PS16384 1:16,384
** WDTPS_PS32768 1:32,768
Thx for you help
Seb
Xbiotec
Post by Xbiotec »
hi Steve,
I tried but not working .
please check the file attached
Pro Compiler install problem .docx
(145.99 KiB) Downloaded 690 times
thx for your help
Seb
Has thanked: 302 times
Been thanked: 469 times
Replace the "pic16_C30_comp.bat" and "pic16_C30_link.bat" files within "%PROGRAMDATA%\MatrixTSL\FlowcodeV9\FCD\PIC16\batchfiles\" with the ones in the ZIP attached to this post.
You should make a backup of the old files first. I've tested and this creates a HEX file for me with the new toolchain.
Note that the same files should work for Flowcode v10 as well (the batch files need to go in the appropriate FlowcodeV10 folder within %PROGRAMDATA%).
Please let us know if this works.
(edit: I have updated the files to allow them to work with spaces in the saved project name)
batchfiles.zip
(2.02 KiB) Downloaded 595 times
Xbiotec
Post by Xbiotec »
with this, I will able to use XC16 pro compiler from microchip ?
it's strange because according to your previous post, the .bat folder file should be in the new install location !
This might work for the new XC16 compiler:
Install the new compiler in a separate location
Copy the "batchfiles" folder from the old installation to the same place as the new one
-- the "batchfiles" folder should be at the same 'level' as the "bin", "etc", "include", etc.
Point Flowcode to the new installer location within Global Options...Locations
-- this location will be the folder containing the copied "batchfiles" folder
Restart Flowcode
how location should be there ?
with this location , compilation failed
how to be sure that XC16 compiler from microchip will be used or is used?
thx
Seb
My previous instructions were wrong. Sorry about that. They should be:
  • Install the new compiler in a separate location
  • Point Flowcode to the new installer location within Global Options...Locations
    -- this location will be something like "C:\ProgramFiles\Microchip\xc16\v2.10"
  • Restart Flowcode
The batch files in the actual toolchain location are no longer used. The ones used are within %PROGRAMDATA% and need to be replaced with the ones I attached earlier.
Also note that changing the toolchain in this way may not fully work. I'm providing these instructions to help you (and others) set up and use the latest compiler. I have not fully tested this new compiler and using it instead of the one we provide may have compilation and execution issues.
Xbiotec
Post by Xbiotec »
Okay
done, how to be sure that Xc16 compiler from microchip is used during compilation ?
Seb
When you click to build, you should get something like the following:
Launching the compiler...
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\PIC16\batchfiles\pic16_C30_comp.bat "E:\ProgramFiles\Microchip\xc16\v2.10\" "xc16_test" "E:\DEV\Flowcode\programs\" "24F08KA101"
The first parameter should be the new toolchain location (for me it is E:\ProgramFiles\Microchip\xc16\v2.10, but yours will be different).
Xbiotec
Post by Xbiotec »
it work's , :D
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\PIC16\batchfiles\pic16_C30_comp.bat  "C:\Program Files (x86)\Flowcode\Compilers\xc16\v2.10\" "PIC24FJ256GA705test2" "C:\Users\seb\Documents\AAA Microchip\" "24FJ256GA705"
thx a lot
Seb
Xbiotec
Post by Xbiotec »
For this pic, I need deepsleep, it seems that deep sleep function is only available in asm could you give me a syntax example to add asm in C ocde .
thx
Seb
Has thanked: 634 times
Been thanked: 840 times
A bit of Googling has come up with this, no idea if it works or not.
Start deep sleep
    // Enclose all in-line assembly in its own function
    asm("MOV #0x8000, w2");
    asm("MOV w2, DSCON");
    asm("MOV w2, DSCON"); // Must repeat writes for GC family devices.
    asm("PWRSAV #0")
End deep sleep
    _RELEASE = 0;
    _RELEASE = 0; // Must repeat writes for GC family devices.
Let us know how you get on.
