HC-SR04
Has thanked: 725 times
Been thanked: 783 times
Re: HC-SR04
Hi Jorgen.
I have replied to the bmp180 post.
ELECTRONICA67
Has thanked: 31 times
Been thanked: 9 times
Re: HC-SR04
Post by ELECTRONICA67 »
Sorry I made a mistake when writing down the information.
Read reading: 55 cm Actual distance: 89 cm
Read reading: 30 cm Actual distance 50 cm
The phase shift is not constant: 20 cm and 34 cm
Enrique
ELECTRONICA67
Re: HC-SR04
Hi Martin and Jorgen,
A previous post was not published where I explained that I had done tests with both sensors, the waterproof and the classic HC-SR04, with both having equal distance readings, but the distance read was wrong, example of readings on the sensors:
1) sensor reading: 55cm --- correct distance: 89cm (error:34cm)
2) sensor reading: 30cm --- correct distance: 50cm (error:20cm)
(error distance is not the same in different distance)
Enrique
Has thanked: 843 times
Been thanked: 205 times
Re: HC-SR04
Post by jgu1 »
Hi Enrique!
I guess that the sensor you use is the waterproof, black an one transduser: This Transduser need a 20uS trig. The HC-SR04 Module as Martin have created a FC component for, give only 10uS trig, it will not work correct with the Waterproof..
If you use the waterproof and you have an Arduino Uno or ect. try to download my testprogram and change the trig from 10uS to 20uS, or you can copy from mine, then it work, at least here by me at the moment. My program is only a testprogram, don´t care with the "temp reading". :)
Hopefully Martin will edit the component in FC so we via proporties or a new component is able to choose devices ;)
Br Jorgen
Distance Sensor Mega - Temp Compensation_v8_God.fcfx
(24.71 KiB) Downloaded 473 times
Flowcode v10 Re: HC-SR04
Hi Enrique & Jorgen.
I was going to modify the component tomorrow, but I had a few minutes spare so I have updated it now.
The component modification will be pushed onto the update system ASAP.
If would you like to test before then, Browse to this location using File Explorer, it's hidden by default so just paste the link into your address bar.
C:\ProgramData\MatrixTSL\FlowcodeV10\Components
If you run any component updates, then the components you added will be overwritten.
Can you let me know if it works for you, please?
I have just tested the HC-SR04 and its reported distance is within 1cm of the expected value.
HC_SR04_Ultrasonic.fcpx
(3.41 KiB) Downloaded 617 times
Re: HC-SR04
Post by jgu1 »
Hi Martin!
Working so perfect, thank you very much :D
In my new testprogram I use an Arduino Mega.
Br Jorgen
HC-SR04_Distance_Sensor_Demo_Arduino_Waterproof.fcfx
(11.44 KiB) Downloaded 655 times
Re: HC-SR04
Hi Jorgen.
Thanks for letting me know.
I have made a minor change, so the selected sensor is displayed on the sensor.
(3.48 KiB) Downloaded 555 times
Re: HC-SR04
Post by jgu1 »
Very nice Martin, push it to update ;)
Br Jorgen
Re: HC-SR04
Post by jgu1 »
Hi Martin!
After update I cannot choose device anymore, have you take the wrong? :lol:
Re: HC-SR04
Hi Jorgen.
I don't believe the update has been pushed yet.
By running the updates, you have gone back to the version previous to my update.
You will need to manually add the component again.
I will let you know when the update has been pushed.
