Hi, I've pm'd you a copy of the component too..
We could perhaps donate all the various components - if there was a suitable 'repository' on this site? (though Peter would need to agree to this for the components he wrote)
Flowcode Exchange
- Has thanked: 156 times
- Been thanked: 902 times
- Has thanked: 429 times
- Been thanked: 647 times
Re: Flowcode Exchange
The Flowcode Exchange was for buying / selling / donating components created by forum members and not for hardware. Maybe someone will have a module you are after and reply. If not then you can easily connect a SIM800L module (available from all the usual markets) and control using v9. If you do a search on this and the "old" forum you will find many examples of using the module.
But I have SIM800C. Is there some problems like software errors if I will use it instead SIM800L?
There is AT commands same like SIM800L. But I ask more about hardware differences. May be there will be a problems with it. I try it to use and in simply project it works correctly. But if my GSM module will work 24/7 in this case what can happen?
kersing
- Has thanked: 81 times
- Been thanked: 65 times
Again, have you checked the data sheets? Do any of the listed differences impact your application?
When it comes to 24/7 operation, make sure there is a way to reset the hardware if it does not perform as expected. That goes for all hardware, not just sim800 modules. And use the hardware watchdog of your controller to make sure it recovers if something unforeseen happens.
This link briefly explains the differences between L/C/F variants. As Kersing mentions, check with the datasheets though as often things change.
https://www.raviyp.com/difference-betwe ... m-modules/
Also take note of what Kersing talks about regarding WDT and resets, especially if the module is to be remote from user. The AT command set is quite powerful so you can perform various checks to ensure you are connected etc.
It has been stated before in posts but is worth mentioning again as it is quite critical to successful operation, that you must ensure an adequate power supply. Don't try and use jumpers from breadboards whilst testing as you are just asking for trouble. You need around 4v at up to 2A (briefly) for reliable operation, but no higher than 4.4v or you risk damage.
I've not deployed one as such but I've tested using one over a period of a week or so. PIC would wake up, connect via the module and send some data. If I remember correctly I used the PIC to power the SIM800 via a FET when needed. I also used it to Tx/Rx SMS messages but obviously the module was on 24/7 for such.
It is a 2G module and many providers are already shutting down 2G and 3G services. In the UK Vodafone announced they will continue to support 2G until 2033 so best to check you are in a service area where you will deploy.
Regarding the m590e module, I don't think it is directly compatible with SIM800 "AT" commands but it shouldn't be too difficult to figure the ones to use.
