Thanks Brendan.
Can you also place the attached component, following the instruction on this post
2D Dashboard running simulation
- Has thanked: 800 times
- Been thanked: 866 times
Re: 2D Dashboard running simulation
- LED_Mono_Custom 2dgi.fcpx
- (6.09 KiB) Downloaded 517 times
I do believe you've nailed it sir !
With the same example project supplied, I've tried both free-running and manually stepping-through with successful results, and particularly with the latter it is now possible to observe all bar LEDs extinguishing immediately upon passing the associated PORTC icon that sets all driving bits low at the start of the flow.
Thank you so much for your time and support on this - Entirely appreciated !
Best regards,
Brendan
Thats great!
Thanks to Steve for his input and thanks for letting us know.
I will arrange for the components to be pushed to the update system.
