Recent update of HCSR04
ELECTRONICA67
Has thanked: 43 times
Been thanked: 11 times
Flowcode v10 Re: Recent update of HCSR04
Post by ELECTRONICA67 »
Hello Jorge,
I made the selection of the component, but it keeps sending 0 zero. :(
Enrique
ELECTRONICA67
config
Has thanked: 910 times
Been thanked: 220 times
Post by jgu1 »
Hi Enrique!
Have you tryed to change the timer and the prescaler and postscaler?
ELECTRONICA67
Hi Jorgen, I will do tests and keep you informed.
Enrique
ELECTRONICA67
Thanks Jorgen and Martin
work with timer1, 1:1, 1:1 with 16 bit timer; The reading is a little unstable, but it sends a reading very close to the real one. I think it is for INT readings 0-65535 and the sensor has a reading of 20-290 that exceeds the 8 bit timer 0-255. I had thought the setting was timer0 1:1 1:1 as the base selection. :D
Enrique
Post by jgu1 »
Ok, at least it begin to work. Play with the Prescaler too.
Martin managed to make it wery flexible.
The att. examble with 8bit Pic work very fine for me, change to your kind of sensor. And for Arduino. Have a look
Good luck :D
Jorgen
HC-SR04_Distance_Sensor__Arduino_WORKING.fcfx
(13.16 KiB) Downloaded 736 times
HC-SR04_Distance_Pic16f876Working.fcfx
(12.24 KiB) Downloaded 644 times
ELECTRONICA67
Thanks Jorgen, I'm going to test these two examples on Arduino and PIC, I appreciate the help.
Enrique
Best Regards
Has thanked: 795 times
Been thanked: 858 times
Thanks Jorgen
Hi Enrique,
If you are still having issues, then can you post your .fcfx file and I will see if I can spot what's going on
ELECTRONICA67
Thanks Martin, I'll let you know, I appreciate the help.
Enrique
Best Regards
