Modbus TCP Slave
WingNut
Has thanked: 50 times
Been thanked: 37 times
Re: Modbus TCP Slave
Post by WingNut »
Is there a lot of difference between the 18f47q43 and the 18f47q84 compiler wise? I have a few of the Q84's.
When do you think the newer xc8 compiler will be employed?
seokgi
Has thanked: 8 times
Been thanked: 8 times
Post by seokgi »
Whenever solve this problem?
I'm sorry for rushing you.
Thank you.
seokgi
Post by seokgi »
Can the MODBUS TCP problem be resolved quickly? If not, please tell me another way to solve it.
seokgi
Post by seokgi »
Please help me.
Did I write the project wrong?
Or is it a functional problem with FC10?
Has thanked: 575 times
Been thanked: 757 times
I've replicated the problem and am working on a fix for you.
seokgi
Post by seokgi »
When will this trouble be resolved?
seokgi
Post by seokgi »
I tested it on MCUs of PIC18F45K40, PIC18F67K40, PIC24FJ512GA606. But it doesn't work at all.
Please let me know any alternative method. I will test it using the method you provided.
Please.
Thank you.
seokgi
Post by seokgi »
Please tell me which MCU (PIC 8-bit or 16-bit) works well and I will change the PCB design to that.
If you give us a working sample program, I will modify the project to fit it.
Please help me.
thank you.
Looks like the bug is in the library somewhere. Looking into it again for you today.
seokgi
Post by seokgi »
Ping works fine, but I still can't open the port. modbus tcp slave cannot run.
Please take a look again.
Thank you
