Hmmmm..... Earlier he said his chip was an ATMEGA328PB. Maybe an oversight in chip selection?
SK6812 LED
- Has thanked: 478 times
- Been thanked: 712 times
Re: SK6812 LED
Ok, thank you Martin. Thought once again it would just work....
Attaching a chart doesn't help much as it's just completely empty. Only the component SK6812 was dragged into the project. Otherwise not a single command.
Re: SK6812 LED
Yes, the chip is a 328PB, the 329P is selected in Flowcode. Martin included the ESP32 as a code example.
Re: SK6812 LED
The only strange thing is that a few days ago everything worked without any problems.
- Has thanked: 177 times
- Been thanked: 1026 times
Re: SK6812 LED
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_RMT.c:112:19: error: conflicting types for 'FC_CAL_RMT_TX_1'
CALFUNCTION(void, FC_CAL_RMT_TX_, (void))
Definitely trying to include the esp code?
If the target is a 328p then there is an issue with the component?
Re: SK6812 LED
Hi Martin
I can compile to Hex without issue if selecting the ATMEGA328P. Without seeing his chart we can only guess...
Re: SK6812 LED
Here is the empy chart...
- SK6812Test.fcfx
- (7.79 KiB) Downloaded 793 times
- (view online)
Re: SK6812 LED
So, I'm one step further. It works again after I restarted the PC and flowcode 1-2 times. Thanks again everyone!
Now I have my old problem again. no matter what values I enter, the led always lights up maximum white.
- Testsk6812.fcfx
- (8.51 KiB) Downloaded 566 times
- (view online)
Re: SK6812 LED
You also need to call Refresh after doing the setall - to upload the data to the leds
Re: SK6812 LED
Unfortunately, it makes no difference whether with or without refresh. Just the initialization command is enough and it lights up white.
