Esp 32 using HC-SR04 PROBLEM
Viktor74
Has thanked: 5 times
Been thanked: 4 times
Re: Esp 32 using HC-SR04 PROBLEM
Post by Viktor74 »
Hello, everyone! Could you please tell me what I'm doing wrong? The compiler gives an error. In the simulator it works fine.
Distance.fcfx
(20.72 KiB) Downloaded 174 times
Has thanked: 800 times
Been thanked: 866 times
Thank you for the bug spot, it looks like there is a sharing violation of timer 0 when there should not be.
To get your project to work you have two options.
1. change timer interrupt from 0 to Timer 2 for example.
Or
2. Change properties of HC-SRO4 to Use Timer Interrupt = Yes.
Change the timer interrupt from 0 to 1 or 2 for example, then change Use Timer Interrupt back to No
I will look into fixing this component .
Viktor74
Post by Viktor74 »
Thank you Martin! Yes, it really works great on Timer2.
Distance.fcfx
(24 KiB) Downloaded 186 times
Thanks Viktor.
I fing using the timer interrupt for HC-SR04, the results are more accurate.
I'm glad your project is know working.
Thanks for letting us know.
