Cannot seem to get the timed event trigger to work
Has thanked: 647 times
Been thanked: 856 times
Re: Cannot seem to get the timed event trigger to work
Hi David,
Currently the component uses the system clock to get accurate timing and this is only accurate to 1 second.
For a higher rate you might be better of using a timer interrupt though this might not be very accurate in the simulation runtime, do you need accuracy on the timings?
