ESP32 LVGL Graphics Library
Has thanked: 156 times
Been thanked: 905 times
Re: ESP32 LVGL Graphics Library
Post by mnfisher »
There is some supplementary code. I've pulled most to macros - and I think most of the rest could also be moved apart from the #includes
Using different displays.
Some displays have code builtin to lvgl (see the first post in this topic for use of st7789) - the need code to send a command (with data) and data to the display. I didn't need to modify the lvgl lv_delay code here as I use FC delays for initialising the display.
The ili9488 isn't supported - so needs a 'flush' to send data to a specified 'window' and an initialisation routine. I've used my own here - the board uses A0..A15 to send parallel data.
lvgl supports multiple displays (the actual hardware) not to be confused with screens (what is displayed - I demonstrate this with the keyboard)
Displaying a jpg is as simple as:
  lv_obj_t * img1;
  img1 = lv_img_create(lv_scr_act());
  lv_obj_align(img1, LV_IMAGE_ALIGN_CENTER, 0, 0);
  lv_img_set_src(img1, "A:/storage/wrens3.jpg");
Note that the jpg decoder is enabled in the lv_conf - if using littlefs (there is a partition set in the sample partitions.csv) then add
littlefs_create_partition_image(storage D:/Projects/Flowcode/Images FLASH_IN_PROJECT)
to main/cmakelists.txt
I didn't get the littlefs support working correctly (and use stdio commands to access the files) - might need some more playing..
Touch works well - for example I tried the bar with a user adjustable position and the calendar widget.
I've barely scratched the surface of lvgl here - there a huge range of styles and widgets - and I have only combined a few (for example a label, roller and button for the initial screen) Have fun!
Ben - how do you turn off the (superbright) LED on the back of the board?
Post by mnfisher »
A couple of other tips.
Use the fastest upload speed you can - I use 921600 but you might get away with 2* this. I changed flowcode's upload to use this speed too.
When flashing from a command line
Idf.py -p COM5 - b 921600 flash
This will also rebuild the program if needed.
Note that it is quicker to build from the command line - flowcode runs export (more than once) but you need to compile to C to create the new file to compile.
This compiled to quite a large program (>1MB) so I altered the partition sizes (the S3 has more space) I didn't try optimising for size....
Post by mnfisher »
See https://squareline.io/ for SquareLine studio - which makes it very easy to design layouts. The code can be cut and pasted into a code block with minor changes (need to declare the variables types (or use the headers). I just tried the 'spinner' widget and working perfectly...
WYSIWYG layout / style etc - very easy to use (and free for personal use!)
Chadb
Has thanked: 32 times
Post by Chadb »
I was just coming here to post this. I was thinking maybe we are barking up the wrong tree. Maybe we should be figuring out how to better integrate getting squareline into flow code.
Chad
Edit: can you post your sample file?
Chadb
Post by Chadb »
Hey, doing some digging.
So it looks like squareline is an offshoot of this. It is free and open source and looks to do about the same for free without the limitations.
Probally isn't as polished but... I am trying to get a test running on Arduino IDE this weekend.
https://www.envox.eu/studio/studio-introduction/
chad
Post by mnfisher »
Looks good - will have a play on return from my travels.
I think it generates lvgl code in the same manner so will still need the lvgl 'glue' shown above.
Let us know how it goes...
