Switch with more decisions
Has thanked: 177 times
Been thanked: 1026 times
Re: Switch with more decisions
Post by mnfisher »
A simple (rather contrived) example.
As Steve mentions - simulation is really not happening here.
There are some advantages over switch statements (at least for lots of options) - the code is smaller and the options run in constant time.
It also 'forces' the code to be split into multiple small macros rather than one large 'do-it-all' macro - which makes for more readable code.
I used an Arduino Nano - which has limited memory - so I can use 16 bit 'pointers'. If the MCU you are using has a larger address space JumpTable needs to be 32 bit. On the esp32 in might be necessary to 'cast' the macro address (FCM_Name) to a MX_UINT32 i.e. FCL_JUMPTABLE[0] = (MX_UINT32)FCM_Name;
One thing demonstrated here is the check on a option being defined - if(fn) - you can have a sparse table if needed.
I don't demonstrate passing arguments (or returning a result) - but it is certainly possible.
Jump.fcfx
(12.59 KiB) Downloaded 308 times
S_VE
Has thanked: 56 times
Been thanked: 4 times
Post by S_VE »
Thank You Martin
S_V
