Compiling error in V7
- Has thanked: 306 times
- Been thanked: 471 times
jollybv
- Has thanked: 42 times
- Been thanked: 15 times
Re: Compiling error in V9
Hi Guys
Im having a little issue compiling again and can seem to be able to find the fault. Also I would like to know where do I find the compiler message that come at the bottom and shows you where the error is and you can click on it and it takes you to the issue. I closed it now cant find it to reopen.
Title: Master Pannel
Description: UNI-CALL Universal intercom syatem
Device: PIC.18F.18F47K40
Generated by: Flowcode v9.3.1.36
Date: Wednesday, May 06, 2026 18:00:21
Users: 1
Registered to: jollybv (54349151)
Licence key: 1WPA8J
https://www.flowcode.co.uk
Using <> user settings for compiler
Launching the compiler...
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\PIC\batch\pic_xc8_comp.bat "C:\Program Files (x86)\Flowcode\Compilers\picv2\" 18F47K40 "C:\Users\BrianHome\Dropbox\Designs and software\U6 Programs 06-10-25\" "E-P_U6_V-4-6-2_W_ON_04-05-26_For-A7682E_AI_repair1"
C:\Users\BrianHome\Dropbox\Designs and software\U6 Programs 06-10-25>REM CRC: 90CF26913586BBA787FE92D553771933222DCF72B25FEB4608E17FBD060500D8A6D7AF8357042D9E8B5C2E833010A32BE2214988CBC1BB00301ECF6745983589FE0D8D4660AC0314F98C28BCA92AF856EFD1DB5B777140BC4D00059D79589982F2C26BF78BFC32C650CACCEB0B5A8E521002EAF3D15174CD20633AD186EC562DBEEF6112EA5AA5CF5041CCE14E8D252BC416ECB8EC7761E4FD518969900F56C6C8F36CE7BEFFD91E73F563CBE7F64B8A69F01B3F3C0F45102C3050DA273BE4EE1BF2A9420263CDAEEC22F549213B2E20A6A0704CBC762DED
C:\Users\BrianHome\Dropbox\Designs and software\U6 Programs 06-10-25>REM REVISION: 1.0
C:\Users\BrianHome\Dropbox\Designs and software\U6 Programs 06-10-25>REM GUID: 50CB4B58-ED9C-4591-8D65-A87DE810E8CC
C:\Users\BrianHome\Dropbox\Designs and software\U6 Programs 06-10-25>REM DATE: 29\03\2021
C:\Users\BrianHome\Dropbox\Designs and software\U6 Programs 06-10-25>REM DIR: FCD\PIC\batch\pic_xc8_comp.bat
C:\Users\BrianHome\Dropbox\Designs and software\U6 Programs 06-10-25>"C:\Program Files (x86)\Flowcode\Compilers\picv2\bin\xc8.exe" --chip=18F47K40 "E-P_U6_V-4-6-2_W_ON_04-05-26_For-A7682E_AI_repair1.c" --MSGDISABLE=359,1273,1388 --FLOAT=32 --DOUBLE=32
C:\Program Files (x86)\Flowcode\Compilers\picv2\pic\bin\picc18 --chip=18F47K40 E-P_U6_V-4-6-2_W_ON_04-05-26_For-A7682E_AI_repair1.c --MSGDISABLE=359,1273,1388 --FLOAT=32 --DOUBLE=32
Microchip MPLAB XC8 C Compiler V2.10
Build date: Jul 30 2019
Part Support Version: 2.10
Copyright (C) 2019 Microchip Technology Inc.
E-P_U6_V-4-6-2_W_ON_04-05-26_For-A7682E_AI_repair1.c:
27773: #warning "This interrupt has previously been enabled, so the macro <Getkey> may never get called."
^ (162) #warning: "This interrupt has previously been enabled, so the macro <Getkey> may never get called." (warning)
27786: #warning "This interrupt has previously been enabled, so the macro <Getkey> may never get called."
27799: #warning "This interrupt has previously been enabled, so the macro <Getkey> may never get called."
27825: #warning "This interrupt has previously been enabled, so the macro <Getkey> may never get called."
27875: #warning "This interrupt has previously been enabled, so the macro <Getkey> may never get called."
27888: #warning "This interrupt has previously been enabled, so the macro <recive_data> may never get called."
^ (162) #warning: "This interrupt has previously been enabled, so the macro <recive_data> may never get called." (warning)
27900: #warning "This interrupt has previously been enabled, so the macro <Getkey> may never get called."
27913: #warning "This interrupt has previously been enabled, so the macro <Getkey> may never get called."
27926: #warning "This interrupt has previously been enabled, so the macro <Getkey> may never get called."
27939: #warning "This interrupt has previously been enabled, so the macro <Getkey> may never get called."
27952: #warning "This interrupt has previously been enabled, so the macro <Getkey> may never get called."
27965: #warning "This interrupt has previously been enabled, so the macro <Getkey> may never get called."
27978: #warning "This interrupt has previously been enabled, so the macro <Getkey> may never get called."
27991: #warning "This interrupt has previously been enabled, so the macro <Getkey> may never get called."
28004: #warning "This interrupt has previously been enabled, so the macro <Getkey> may never get called."
28017: #warning "This interrupt has previously been enabled, so the macro <Getkey> may never get called."
28030: #warning "This interrupt has previously been enabled, so the macro <Getkey> may never get called."
28043: #warning "This interrupt has previously been enabled, so the macro <Getkey> may never get called."
28056: #warning "This interrupt has previously been enabled, so the macro <Getkey> may never get called."
28069: #warning "This interrupt has previously been enabled, so the macro <Getkey> may never get called."
28082: #warning "This interrupt has previously been enabled, so the macro <Getkey> may never get called."
E-P_U6_V-4-6-2_W_ON_04-05-26_For-A7682E_AI_repair1.c: main()
14612: }
^ (195) expression syntax
^ (312) ";" expected
15580: break;
^ (345) unreachable code (warning)
(908) exit status = 1
Error returned from [xc8.exe]
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\PIC\batch\pic_xc8_comp.bat reported error code 0x1
Autoclose turned off
FINISHED
Users: 1
Licence key: 1WPA8J
14612: }
15580: break;
FINISHED
