Inserts in C do not work.
carworker
- Been thanked: 3 times
Re: Inserts in C do not work.
Thank you. The learning process is exciting but I think we should stop. Now my task is to switch to a more recent platform. I am engaged in electronics repair and FC as an additional tool. I am thinking which package to choose. I am quite satisfied with the PIK8 package but then there will be no access to functions that are only available for the PRO package. For example, Desision - Costomize C code. Is this true?
Thank you. The learning process is exciting but I think we should stop. Now my task is to switch to a more recent platform. I am engaged in electronics repair and FC as an additional tool. I am thinking which package to choose. I am quite satisfied with the PIK8 package but then there will be no access to functions that are only available for the PRO package. For example, Desision - Customize C code. Is this true?
- Has thanked: 165 times
- Been thanked: 967 times
Flowcode v10 is free to use as a hobbyist - so you can get a good feel for what it can do. There are limitations on targets, but I think everything else is included (?) - someone may correct me on this. Flowcode provides a rather more pleasant programming environment than C - all the code so far has been C - but generally you don't have to delve into the inner workings like here.
The simulation and other tools are remarkably rich - I've been using flowcode for maybe 8 years and sometimes feel that I've barely scratched the surface of its features when I discover something 'new'.
There is also the opportunity to build PC apps...
It isn't perfect - no language is - but you'll find the support from users and the matrix staff is second to none.
- Has thanked: 294 times
- Been thanked: 458 times
Thanks Steve,
Most everything is included....
Looking at the list there are plenty of things I didn't know it could do - still much to explore!
