PIC12f510
carworker
Been thanked: 3 times
Re: PIC12f510
Post by carworker »
This example works in the simulator. Pay attention to the project options. Do not set "automatic erase". If it does not work in hardware, you will need to restore the calibration constant using a programmer
Test Routine.fcfx
(7.82 KiB) Downloaded 275 times
Has thanked: 177 times
Been thanked: 1016 times
Re: PIC12f510
Post by mnfisher »
alanwms
Has thanked: 27 times
Been thanked: 8 times
Re: PIC12f510
Post by alanwms »
I was using osccal after I ran out of ideas. I did understand that this was for frequency precision adjustment. For the MCLR bit - I actually have a measured VDD value. It is connected to VDD via a 1k resistor. There may not be a bug, but I have a feeling that the config is not downloading. I'm also a little confused regarding the config settings in FC. The check box for downloading the osc parameters can be checked to download when the program is downloaded. There is a button for "download now", but it doesn't seem to do anything - Certainly there is no indication on the screen that something happened?
Has thanked: 772 times
Been thanked: 831 times
Re: PIC12f510
There is a way of checking if the configuration settings are present within the hex file or not.
Can you send me the hex and .msg files from FC10, then I will let you know.
carworker
Re: PIC12f510
Post by carworker »
I remove this tick and it starts working. If you are programming the chip not from the FC environment but through the programmer, load the file "cof". Try mine
Test Routine.rar
(1.97 KiB) Downloaded 291 times
carworker
Re: PIC12f510
Post by carworker »
Bit 4 - Enabled. Apply this reset scheme. Configuration word is present in file "сof" 0x3ffa
Re: PIC12f510
Instead of using 12F510 which as 1.5k Flash Rom, therefore will run out of code very quickly.
What about trying 12F1840 which has 4k Flash Rom and in internal osc of up to 32MHz
alanwms
Re: PIC12f510
Post by alanwms »
12F1840 is a great device. Thanks for the heads up. I like the speed on the intosc.
