WS2811
Has thanked: 794 times
Been thanked: 853 times
Re: WS2811
The fixed file is now on the component database.
You can now update to the correct version by changing Files in-use to Full database.
This time don't have Show up-to-date files enabled.
After updating the component, you will need to reload your project.
TheShadowOfTriumph
Re: WS2811
Post by TheShadowOfTriumph »
After last updates my led works fine.
It remains to find out the secret of the parameter "STARM instruction rate", now it gives funny values ​​on the oscilloscope (the LED still works).
What should be its value at PLL = 8 MHz?
TheShadowOfTriumph
Re: WS2811
I came back to tell where the glitch really was.
Now my device has a keyboard with RGB buttons based on the WS2811 IC.
I used to have the following parameters HSI(8M)/2 and PLL multiplier x2. Now i change PLL to x8 and project frequency to 32M. WS2811 stop glitching. This is probably worth mentioning to the wiki. Perhaps this approach will improve performance with other components as well.
