Sending Data over Cellular Networks
viktor_au
Has thanked: 11 times
Been thanked: 19 times
Re: Sending Data over Cellular Networks
Post by viktor_au »
In short, Tx as
AT+CSMS?
AT+CREG=1
AT+CSQ
AT+CMGS="0xx8x2x5xx" //insert your phone N, wait for “>”
Hello //enter any text
Press on keyboard Ctrl Z
SMS should be sent to the mobile phone
Has thanked: 447 times
Been thanked: 674 times
Hi Viktor
If I use a keyboard then things work as you document, but if I create a Macro which has my message and termination character, I need to use the SUB character (Hex 1A). I suspect if I use Flowcode to create predefined messages then I would need to use 1A as termination.
I haven't tested this though.
viktor_au
Post by viktor_au »
Hi.
Did you use Putty and all worked?
You can get a sms to your mobile phone?
No problems?
Hi Viktor
I'm not using PuTTY but another Terminal program. Using it I can get the module to dial out and it can send and receive SMS messages. The only issue is that I need to use Hex 1A to terminate the message string, which contradicts documentation.
I now have it communicating with ThingSpeak but there is a problem with what I'm sending as the server returns 400 or 406. Probably something silly I've overlooked (I hope).
viktor_au
Post by viktor_au »
OK
viktor_au
Post by viktor_au »
Understood. Thank you. What terminal do you use?
Usually I use "Terminal by Br@dy" as it allows me to create Macros so I just need to press a button to send a string of characters. On another machine I have a few programs including PuTTY, so maybe I'll try with them.
viktor_au
Post by viktor_au »
Thanks.
Would be great for people, who follow this project if you can share the code on Terminal v1.9b by Br@y++.
Can you share?
Hi Viktor
For making the call and sending SMS messages I have already.
I have now found some documentation on a Google search that does actually refer to Hex 1A to terminate, calling it ctrl+z / esc, but my ascii chart refers to it as Sub with Hex 1B as Esc.
I have only had to use that when terminating the actual message when sending a SMS and I am over the USB-USB connection. Not ruling out that being a contributing factor either.
I will use the Tx/Rx pins when I get a chance, for comparison.
viktor_au
Post by viktor_au »
I am a bit lost.
Are you working now in FC10?
