I tested with the osciloscope and
C-code is working to set the Pin to 1
Clock is working
CS is working
MOSI is alway 1
MISO is alway 1
STM32F469I-DISCO board SD-Card Pin not available
- Has thanked: 245 times
- Been thanked: 257 times
Re: STM32F469I-DISCO board SD-Card Pin not available
Hi LeighM, Hi Marti
Yes it's working in software mode. With the SPI unfortunately not yet.
The software mode is usually too slow. I will try it out.
It would be an advantage if it works with the SPI Hardware.
I will also try it with the hardware from the post, which I will also use
viewtopic.php?t=3053
Setup working in softwaremide
I think that the card with this pin can only be used with SDMMC and not in the SPI bus.
With the ESP32 there is this possibility. Could you do the same for the STM32?
especially because the software mode is much slower than the SPI hardware as even worse in comparison with the SDMCC
SPI is slower (~0.5-2 MB/s vs. ~10-20 MB/s with SDMMC)
Hi LeighM, Hi Martin
I have tested in software mode but it is much too slow for my application. I can write a wave file, but with a few kByte it takes minutes.
Would it be possible to have a component to use the SD disk in sd-mmc with 4bit like esp32?
