ESP32 ADC not working
simisv
Has thanked: 5 times
Been thanked: 5 times
Re: ESP32 ADC not working
Post by simisv »
On Wroom module ADC1 is safe with WiFi and Bluetooth,
I'm guessing is the same with S3 module , not sure yet .
Definitely after some tests I will know ( but first I need to build the prototype board).
Anyway, on this project is not used.
Xbiotec
Has thanked: 37 times
Been thanked: 27 times
Flowcode v10 Re: ESP32 ADC not working
Post by Xbiotec »
I'm on customer side in Asia and i'm trying to use on ESP32-u4wdh Pin20 AN36 on (Flowcode Strange notation) who on ESP32 is Pin20 GPIO13 on ADC2_Ch4, not on same Channel as others.
Why Pin name are different ?
for information, I'm using ESP32-u4wdh since long time
ESP32 pin20.png (13.4 KiB) Viewed 8032 times
It's not possible to adjust channel in component properties.
- ESP32 reboot
UART1 Started, [0;31mE (2419) adc_oneshot: adc_oneshot_config_channel(150): invalid channel[0m
14:27:27.245 -> ESP_ERROR_CHECK failed: esp_err_t 0x102 (ESP_ERR_INVALID_ARG) at 0x400d80a9
14:27:27.279 -> file: "C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ESP\ESP_CAL_ADC.c" line 109
14:27:27.285 -> func: FC_CAL_ADC_Enable_1
14:27:27.285 -> expression: adc_oneshot_config_channel(adc_handle, Channel, &config)
14:27:27.285 ->
14:27:27.285 -> abort() was called at PC 0x40086c1b on core 0
It's not a question of delay in main loop.
I have remove everything on my program to check if the problem is not linked to another component.
Same problem
I ahev test all ADC components to see if there is at least one where we could change the Channel.
No way
I'm not using WIFI nether Bluetooth
Program attached
ESP32-u4wdh datasheet attached
So I think it's ADC component problem or ADC cal problem , I don't know
Please find a way asap to be able to use ADC
As I said I'm on customer side and for me it's 15h27 !
thx
esp32_datasheet_en.pdf
(970.45 KiB) Downloaded 350 times
ADCread_ESP32_U4WDH_V0.1.fcfx
(19.99 KiB) Downloaded 355 times
Seb
Has thanked: 794 times
Been thanked: 853 times
Hello Seb.
You don't need to use WiFi components, its just wifi is enabled by default.
THe reason being is more people use ESP32 for WiFi than they do for ADC.
Therefore if you use any ADC's that are ADC2 which is most, then they will cause a reset.
Have you tried just using ADC that are on inputs only at least then that will free up other pins for I/O or O/P tasks.
For example you can try An0, An3, An4, An5, An6 or An7?
Xbiotec
Post by Xbiotec »
Hello Martin,
I can not use another ADC, PCB already made. (20 PCBA)
You mean in flowcode, WiFi is enable by default?
So how to disable and solve this ADC problem?
Seb
Xbiotec
Post by Xbiotec »
Nothing to tell me?
Seb
Has thanked: 177 times
Been thanked: 1026 times
Post by mnfisher »
Can you try the code on page 1 of this topic - check the output from UART (using PuTTY or similar) - it will let you know if the pin is available etc?
Xbiotec
Post by Xbiotec »
Hi, the pin is available for ADC but on ADC2 channel4 , I'm sure, I have asked to Espressif, they said , no mistake on datasheet.
The problem is because ADC components in flowcode do not manage ADC2 Channel 4.
download/file.php?id=9356
Seb
Post by mnfisher »
The code I posted on the previous page doesn't use the component - and should work correctly - however, it will take a bit of re-work in your code.
Xbiotec
Post by Xbiotec »
ok I will try
But Flowcode team must check and make it working on all ADC on FC10 for ESP32
Seb
Xbiotec
Post by Xbiotec »
mnfisher wrote: ↑
Fri Jun 20, 2025 12:59 pm
Thx it's works after few modifications and AI help
Seb
