DMX master has issues
Has thanked: 163 times
Been thanked: 960 times
Re: DMX master has issues
Post by mnfisher »
How did you do the 'heartbeat' pulse - with an interrupt or in the main loop. If the UART isn't quite initialised correctly then the wait for transmission to finish - may never return.
I did get output with the FC component - but that was with a PIC32 and checking the output on the oscilloscope - the UART decoder didn't make great sense of the values sent...
Has thanked: 442 times
Been thanked: 661 times
As per the chart, straight after setting the oscillator I pulsed the heartbeat, then held the pin high after DMX initialising. As the pin goes high, then we returned from initialising.
I replaced Martin's "initialisation" with the FC component.
I then got a trace on C7 (hardware pin).
Screenshot 2025-06-07 104733.jpg (54.67 KiB) Viewed 2003 times
However I notice in the decoded results that there is a warning that the MAB is too short (Mark After Break). I would need to read up on DMX protocol but this could possibly be accounting for the errors, as perhaps it is knocking timings out?
I've not went further but may get a chance to look further later.
Post by mnfisher »
Whilst waiting for a 16F18877 to arrive in the post - I tried a different MCU.
So with a PIC16F887 (which is rather a lower specced beast) - I got a simple DMX output running (I think)
Here outputting 24 channels (set to 0..23) My logic analyser reads the 'start' pulse as 0.
I'm using '0' as the control byte too (this could be set as data[0] or passed as a parameter depending on requirements but at present SendDMXPacket has it hardcoded as 0.
This is with the MCU running at 8MHz
dmx887.fcfx
(13.7 KiB) Downloaded 114 times
Post by mnfisher »
While I was typing - Iain popped in with a test of the DMX component too. I don't have a way to test if it is a valid DMX signal - how doing?
I was running on a 18877 @ 32MHz
From memory you don't need a reply from your DMX receiver (I could be wrong) so in theory a decoder built into your scope/analyser may help, but of course any actual DMX receiver would be best.
Further to above, I haven't looked at the component but would it be possible to increase the MAB from the current 2.06uS ?
From the web it suggests it should be 8uS but who knows how accurate that source is?
Post by mnfisher »
Just using the UART decoder at present. Just checking if sigrok will do the trick...
beneee
Has thanked: 1 time
Post by beneee »
I have tried running Martins file on my 18877 setup to see if the output is a valid DMX signal however it won't compile to target.
Ben
This is the error:
G:\My Drive\Moonwalk\Moonwalk 2025\DMX Pic>"C:\Program Files (x86)\Flowcode\Common\Compilers\picv2\bin\xc8-cc.exe" -mcpu=16F18877 "dmx887.c" -w=359,1273,1388 -fno-short-float -fno-short-double -std=c90 -Os
dmx887.c:143:1: error: (192) undefined identifier "OSCCON"
(908) exit status = 1
Error returned from [xc8.exe]
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\PIC\batch\pic_xc8_comp.bat reported error code 0x1
I could download it to a 18877 without issue, but when run my decoder informs that the MAB is to short (being 2.06uS).
This may be a typo in the component. Perhaps Matrix could check?
