Not happy looking for examples
RGV250
Has thanked: 41 times
Been thanked: 42 times
Re: Not happy looking for examples
Post by RGV250 »
I did have a quick look.
The Raspberry Pi HDMI component did work on hardware target, but didn't seem to simulate in Flowcode.
I used a simple Initialise and Hello World print.
Would it be possible to post your hello world example as I do not get anything at all on real hardware. It just stays on the Pi home screen or whatever it is called.
Do I need to change any settings?
Bob
Has thanked: 94 times
Been thanked: 288 times
My earlier tests were with a quick grab of a Raspberry Pi 2 (as it has the full size HDMI socket)
Now I've tested on Raspberry Pi 4 with latest operating system, I now see the problem.
It's a glibc version issue. The compiler isn't compatible with the latest Raspberry Pi OS.
There is a "simple" fix though.
Add -static to the compile batch file rbuild.bat found in C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\RPI\batch
Line 15
@"%MX_COMPILER%gcc\bin\%MX_CC%" -w "%MX_PROJECT%.c" -lm -o "%MX_PROJECT%"
Becomes...
@"%MX_COMPILER%gcc\bin\%MX_CC%" -static -w "%MX_PROJECT%.c" -lm -o "%MX_PROJECT%"
Created executables will now be larger, but will run on any versions of Raspbian/Raspberry Pi OS
RGV250
Post by RGV250 »
Thanks, I will have a look over the weekend. Mine is a 3B but using the latest OS.
Just a thought, if it works I wonder if it will be overwritten if you update FC in the future?
Perhaps it could be written in so there is a "Use HDMI" option when compiling so if not needed the exe size would not be changed?
Bob
Has thanked: 425 times
Been thanked: 646 times
Hi Bob
Mine are mainly 3B too and like you have lastest OS installed.
Very helpful posts.
Yes, it's a modification that Matrix need to implement. (Please guys :D
The issue will affect more than just this component.
The other option is to upgrade the compiler to match the glibc version of the operating system. But that's like aiming at moving goal posts.
Another option would be to compile on the Raspberry Pi, rather than cross compile on the PC. That would be slower, but guarantee compatibility :lol:
RGV250
Post by RGV250 »
I made the change to rbuild and made a simple test but nothing happened. FC says it is running after download but the Pi display just shows the screen as it does after boot. I tried to run the file directly but still nothing.
Can someone test the program to see if I am doing something wrong.
HDMI_Test.fcfx
(9.55 KiB) Downloaded 197 times
Bob
Could you try running as root, or sudo ?
I'm away from PC at the moment.
Works for me, without sudo (with obviously changed login credentials)
Although, I'm not running a desktop, just a console, but as I recall that shouldn't make any difference.
I think I've written notes previously, either on the wiki or the old forum, about disabling the desktop, and disabling the console.
This component simply writes to the frame buffer, as do console and desktop.
When running the program directly (from a console) do you get any (error) messages?
