Error message: PICO Compiler Toolchain is not installed.
HansJuergenHalder
Re: Error message: PICO Compiler Toolchain is not installed.
Post by HansJuergenHalder »
Yes, you are right, the program is only used to simulate the error.
The folder C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\PICO
exists and the files it contains make sense.
The storage medium still has sufficient space. I also have no problems programming the RP2040 via VS Code.
HansJuergenHalder
I was able to fix the error and reconstruct it.
Flowcode enters the folder under RPI. I copied the entry and entered it in PICO.
Has thanked: 478 times
Been thanked: 713 times
Glad to hear you have it working.
I like the Pico as a target.
HansJuergenHalder
The folder exists with files and subfolders.
Has thanked: 794 times
Been thanked: 858 times
Your project file compiles OK for chipfryer27 and myself.
For that reason I have moved your topic from Bugs, since it's not a toolchain or Flowcode Bug.
