Failing to perform latest sw update
kramtlas
- Has thanked: 7 times
- Been thanked: 2 times
Re: Failing to perform latest sw update
Hi Steve, I have tried your suggestions but Flowcode still failed to update. I also uninstalled and reinstalled but the outcome was the same. I have now installed Flowcode v9.0 which works OK until you have a solution. But I would like to be able to update to v9.1 as soon as it is possible. Thanks Mark.
- Has thanked: 311 times
- Been thanked: 479 times
Hi Mark,
The initial problems with the update were caused by Flowcode being blocked by some anti-virus programs. This appears to no longer be an issue, so I'm not sure why it is still a problem with your PC. Maybe you need to update your antivirus signatures. Another possible solution is to restart your PC is Safe Mode and then attempt the update.
Failing that, we do plan to update the main Flowcode installer to v9.1. I will try to ensure this is available later this week.
