Embedded AI
Has thanked: 165 times
Been thanked: 967 times
Re: Embedded AI
Post by mnfisher »
The type of 'w' looks to be incorrect.
It would need to be a 2 dimensional array of floats for the code to compile.
Float w[10][10]
for example.
I would guess it is just an array and you are attempting to pass a single element to calculate.
Float w[10]   - w[i]
is a float not an array. (An oddity in the forum code -
w[i]
displayed as just 'w' if not on a code block) - if this is the case the parameter would need to be w.
Please attach your code demonstrating errors like this (full editor attachments or drag and drop to the full editor window) as we can only guess what is happening without seeing the full code.
Has thanked: 296 times
Been thanked: 459 times
Re: Embedded AI
If w[] is a one-dimensional array, just pass "w" as the parameter.
17712885438
Been thanked: 2 times
Re: Embedded AI
Post by 17712885438 »
Why is there no output for this example z?
neuron1.fcfx
(16.05 KiB) Downloaded 31 times
Has thanked: 618 times
Been thanked: 818 times
Re: Embedded AI
How's this? I've tweaked your file slightly and it seems to be working now.
neuron1.fcfx
(17.13 KiB) Downloaded 16 times
