Curiosity Nano pic18f47k42 does not work .
ahmetimanli
Re: Curiosity Nano pic18f47k42 does not work .
No. I don't see any exclamation marks. I sent screenshots of the Device Manager and Flowcode v11 Project Options with the card installed. I don't see any hardware in the Programmer Port. The Programmer Port is not active.
- Has thanked: 478 times
- Been thanked: 712 times
As it doesn't work under MPLAB either it is more likely a faulty USB lead or PC issue such as a driver issue.
Without having one I may not be of great help. However in Device Manager do you see the board appear / disappear when you plug / unplug?
If so, do you have an option to update drivers for it?
A web search informs that the drivers should be installed automatically with MPLAB but you may need to reinstall MPLAB.
ahmetimanli
merhaba.matlab'ı tekrar güncelleyeceğim.umarım dediğiniz gibi olur.teşekkür ederim.
