Arduino + 16 x 2 LCD + LCM1602 I2C Adaptor
Has thanked: 724 times
Been thanked: 783 times
Re: Arduino + 16 x 2 LCD + LCM1602 I2C Adaptor
oadramos wrote:
Fri Oct 29, 2021 6:01 pm
fixed it now. i was trying both addresses that "as suggested" previously....then saved at wrong place. see attached please.
Yes that looks correct.
Can you see correct chars on your display now?
oadramos
Has thanked: 4 times
Post by oadramos »
No Sorry i cant.
if i open arduino IDE now and program it, it then shows me "Hello World"
oadramos wrote:
Fri Oct 29, 2021 6:09 pm
That is excellant news.
Thanks for letting us know.
oadramos
Post by oadramos »
medelec35 wrote:
Fri Oct 29, 2021 6:26 pm
I'm very sorry, i didnt mean it that way. My dad has been bragging about flow code since flowcode probably 1.0
I decided i have sometime and wanted to try it out... I'm sure its just something im doing silly.
oadramos
Post by oadramos »
Does this look right?
Title:
Description:
Device: ARD.ATMEGA.ATMEGA328P
Generated by: Flowcode v9.2.0.33
Date: Friday, October 29, 2021 19:56:46
Users: 1
Registered to:
Licence key:
NOT FOR COMMERCIAL USE
https://www.flowcode.co.uk
Compilation is up-to-date
Linking is up-to-date
Using FCD settings for programmer
Launching the programmer...
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\AVR\batchfiles\avrc_arduinoA.bat "C:\Program Files (x86)\Flowcode\Common\Compilers\avrv5\" m328p arduino COM3 115200 "D:\Dropbox\Oliver Work 2020\FlowCode\Flowcode2.hex"
D:\Dropbox\Oliver Work 2020\FlowCode>REM REVISION: 1.0
D:\Dropbox\Oliver Work 2020\FlowCode>REM GUID: BC89C337-8FBB-43B7-A3A7-C7902C121931
D:\Dropbox\Oliver Work 2020\FlowCode>REM DATE: 29\03\2021
D:\Dropbox\Oliver Work 2020\FlowCode>REM DIR: FCD\AVR\batchfiles\avrc_arduinoA.bat
D:\Dropbox\Oliver Work 2020\FlowCode>"C:\Program Files (x86)\Flowcode\Common\Compilers\avrv5\bin\avrdude.exe" -pm328p -PCOM3 -b115200 -carduino -D -Uflash:w:"Flowcode2.hex"
avrdude.exe: AVR device initialized and ready to accept instructions
Reading |
################################################## | 100% 0.00s
avrdude.exe: Device signature = 0x1e950f
avrdude.exe: reading input file "Flowcode2.hex"
avrdude.exe: input file Flowcode2.hex auto detected as Intel Hex
avrdude.exe: writing flash (1150 bytes):
Writing | ################################################## | 100% 0.18s
avrdude.exe: 1150 bytes of flash written
avrdude.exe: verifying flash memory against Flowcode2.hex:
avrdude.exe: load data flash data from input file Flowcode2.hex:
avrdude.exe: input file Flowcode2.hex contains 1150 bytes
avrdude.exe: reading on-chip flash data:
Reading |
################################################## | 100% 0.14s
avrdude.exe: verifying ...
avrdude.exe: 1150 bytes of flash verified
avrdude.exe done. Thank you.
Programming successful!
FINISHED
oadramos
Post by oadramos »
I have now swopped out the arduino boards and changed the wires. And still....
If the wording is wrong after recompiling then the hardware has not been updated with the correct flwochart.
If the address is wrong then there will be a row of squares as the LCD has not ben correctly initilised.
As a sanity check, you can can confim the address is correct by using my I2C sniffer.
oadramos
Post by oadramos »
medelec35 wrote:
Fri Oct 29, 2021 8:32 pm
This looks bad???
oadramos
Post by oadramos »
I even tried another LCM1602 Board and sniffed the same result.
another i2c board.jpg (75.04 KiB) Viewed 7334 times
oadramos
Post by oadramos »
Just in case it helps...
My Arduino IDE code sketch that is working on current setup... Maybe it can help?
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
// Set the LCD address to 0x27 for a 16 chars and 2 line display
LiquidCrystal_I2C lcd(0x27, 16, 2);
void setup()
// initialize the LCD
lcd.begin();
// Turn on the blacklight and print a message.
lcd.backlight();
lcd.print("Hello, world!");
void loop()
// Do nothing here...
