Circularbuffer Getbyte get out wrong data position
Has thanked: 311 times
Been thanked: 479 times
Re: Circularbuffer Getbyte get out wrong data position
There is no fix for this. Please continue to use the workaround of setting the buffer size to one more than the actual quantity you wish to store. That way it seems to work ok.
Xbiotec
Has thanked: 37 times
Been thanked: 27 times
Post by Xbiotec »
hi,
Even with setting the buffer to one more, the second issue is still there who I'm talking today is still there!
Capture d’écran 2022-02-18 170300.jpg (53.63 KiB) Viewed 5219 times
Did you tried the program sent to you ? :?
Seb
Sorry - I saw you say "still no news since the end of December" and I assumed you were raising the same issue again. I'm personally not that familiar with the Circular Buffer component, but I will have a look next week and see if I can suggest another workaround.
Xbiotec
Post by Xbiotec »
hi Ben and Steve,
Still no news about this problem ?
Seb
Ben has told me the following:
There is a property to allow you to keep old data or new data when filling the buffer past it’s limits, has Seb set this property correctly?
The CB is known to work very well the only limit it currently has is you cannot fill it up 100% for a set amount of data you need 1 extra byte.
Unfortunately, I'm not that familiar with this component. Does the above help?
Xbiotec
Post by Xbiotec »
may be I'm wrong I will check carefully later.
Thx for your help
Seb
