DSP FIR filter component coefficients
Oscar_T
Has thanked: 37 times
Been thanked: 10 times
Re: DSP FIR filter component coefficients
Post by Oscar_T »
I can't compile the program correctly, it gives me the following errors
../main/esp-project.c: In function 'FCD_0c101_Ref1__Prv_GetConsole':
../main/esp-project.c:497:25: error: 'FCL_DATA[<unknown>]' is used uninitialized in this function [-Werror=uninitialized]
FCR_RETVAL = FCL_DATA[FCL_BYTE] | (FCL_DATA[FCL_BYTE + 1] << 8);
../main/esp-project.c:497:47: error: 'FCL_DATA[<unknown>]' is used uninitialized in this function [-Werror=uninitialized]
../main/esp-project.c: In function 'FCD_09991_Buff1__Prv_GetConsole':
../main/esp-project.c:1141:25: error: 'FCL_DATA[<unknown>]' is used uninitialized in this function [-Werror=uninitialized]
../main/esp-project.c:1141:47: error: 'FCL_DATA[<unknown>]' is used uninitialized in this function [-Werror=uninitialized]
../main/esp-project.c: In function 'FCD_0c101_Ref1__Prv_PutPropStr':
../main/esp-project.c:247:16: error: 'FCL_RDSTR[<unknown>]' may be used uninitialized in this function [-Werror=maybe-uninitialized]
if (FCL_RDSTR[FCL_RDIDX] == ',')
../main/esp-project.c: In function 'FCD_0c101_Ref1__Prv_GetPropStr':
../main/esp-project.c:410:16: error: 'FCL_RDSTR[<unknown>]' may be used uninitialized in this function [-Werror=maybe-uninitialized]
../main/esp-project.c:429:16: error: 'FCL_RDSTR[<unknown>]' may be used uninitialized in this function [-Werror=maybe-uninitialized]
../main/esp-project.c: In function 'FCD_09991_Buff1__Prv_PutPropStr':
../main/esp-project.c:884:16: error: 'FCL_RDSTR[<unknown>]' may be used uninitialized in this function [-Werror=maybe-uninitialized]
// } else {
../main/esp-project.c: In function 'FCD_09991_Buff1__Prv_GetPropStr':
../main/esp-project.c:1054:16: error: 'FCL_RDSTR[<unknown>]' may be used uninitialized in this function [-Werror=maybe-uninitialized]
// } else {
../main/esp-project.c:1073:16: error: 'FCL_RDSTR[<unknown>]' may be used uninitialized in this function [-Werror=maybe-uninitialized]
} else {
instead if I remove the dsp components everything is ok
Oscar_T
Post by Oscar_T »
Did you find out why it can't compile when I insert the dspwavegenerator?
Has thanked: 554 times
Been thanked: 740 times
Hi Oscar,
Yes I've found the cause of the problem now and am on with fixing it.
Edit, should be fixed for you now ;)
Oscar_T
Post by Oscar_T »
Hi, I would like to dedicate this week to debugging the interface to try to make it work. Now I am able to compile everything correctly but the i2s port does not work. I have a logic analyzer to see what the i2s port is pulling out.
The settings are as follows
FS 48Khz
16 bit
Stereo
I will not select other modes because I have seen anomalous behavior with some configurations so I will focus on this which is still very common the clocks, as mentioned some posts before are ok.
Next to the esp32 I have my dsp with which I can generate the signals and compare them. For example, if with my dsp I generate all 0's on the output signal, actually with the logic analyzer I display all 0's.
Instead with esp32 I set all the buffer to 0 in output I have values ​​other than 0
Hi Oscar,
Brlliant hopefully together we can make this work correctly. Can you post your latest project so I can see exactly what you're doing and I'll have a play here and see if I can make sense of it. My logic analyser can parse I2S data so I'll try with that.
Oscar_T
Post by Oscar_T »
I am attaching both the program and an excel table of the logic analyzer
esp32_i2s.xlsx
(20.99 KiB) Downloaded 680 times
esp32_I2S_Sine.fcfx
(8.89 KiB) Downloaded 629 times
Thanks Oscar,
Just noticed in your code you are likely leaving AUDIO_BUFFER_1[0] uninitialised and probably overflowing the bounds of the buffer too.
AUDIO_BUFFER_1[a+1] = 0
should instead be.
AUDIO_BUFFER_1[a] = 0
Testing on hardware now to see what I get here.
Oscar_T
Post by Oscar_T »
Sorry for the stupid mistake!!! I have compiled again but continue to get values ​​other than 0 on the i2s signal
Yes there's something certainly up I cansee there is lots of random data appearing, not the data that is being written.
I'll keep playing with it and see if I can find a way to tame it.
Oscar_T
Post by Oscar_T »
ok
How are these parameters set by the driver?
channel_format = I2S_CHANNEL_FMT_RIGHT_LEFT,
.communication_format = I2S_COMM_FORMAT_I2S | I2S_COMM_FORMAT_I2S_MSB.
Because these parameters must also be set in order to communicate in I2S standard.
I don't know if this rtos based example can help you https://github.com/SuperHouse/esp-open- ... _example.c
