Yes, sorry, we don't have a lot of control over the Espressif toolchain.
Renaming the account might not work because the Espressif installer sets up numerous tools and paths (that might then be broken)
I think Flowcode installs accessible to everyone and might setup the registry for the new user on first run, but Steve will have a better idea on that.
ESP32 not compling to chip
- Has thanked: 110 times
- Been thanked: 302 times
- Has thanked: 311 times
- Been thanked: 479 times
Re: ESP32 not compling to chip
You will not need to reinstall Flowcode for another user on the same PC. However, you will need to reactivate the licence.
Note that due to a bug with the current release of Flowcode, you will need to activate the trial licence for this new user account first. After restarting Flowcode, you will be able to select "my licence" from the Licensing...manage screen.
DAVIDJOINER
- Been thanked: 18 times
1 Created new user with no spaces in Windows 10 ("DAJ")
2 reloaded ESP tool chain
3 Ran FLOWCODE 9 and tried to compile but still not compiling fully
4 Have enclosed compiler msg file again
5 Even removed Flowcode 9 and re installed and still same result
This is getting rather frustrating
David
David
- test6.msg.txt
- (1.95 KiB) Downloaded 960 times
Hi David,
It's frustrating for us too! To me it looks like there is a problem with the installation of the ESP toolchain, but I'm not an expert - others on this forum should have a better idea. As the toolchain is a 3rd party product with its own installer, it is sometimes difficult for us to offer a solution. But we can try...
I've searched for the error messages you are receiving and I've found these 2 posts:
https://esp32.com/viewtopic.php?f=13&t=12362
https://github.com/espressif/esp-idf/issues/3879
The first link in particular appears to show the cause. During the install of the ESP toolchain, the environment variables have not been set up correctly. Perhaps this info will help you, or might point others towards the cause so they can offer a solution.
Hope this helps,
Steve.
Hope this helps,
Steve.
Yes, I'm thinking similar to Steve.
You might need to try manually adding the paths of esp-idf and esp-idf/tools to the system PATH variable.
Also please check that the PATH variable is not at the 2048 character limit of Windows 10
DAVIDJOINER
1 "Re You might need to try manually adding the paths of esp-idf and esp-idf/tools to the system PATH variable."
How do i actually do this
2. Also please check that the PATH variable is not at the 2048 character limit of Windows 10
Have read the links you sent a bit hard to fully grasp but hopefully we are getting closer
but not quite there yet
David
David
- Has thanked: 794 times
- Been thanked: 853 times
I have just installed ESP on a fresh windows install.
I have had issues in the complying to target.
The way I got around it was:
1. Install esp-idf-tools-setup-2.3 in Admin mode.
2. Only select python 3.7, even if you have later version already installed.
2. You can use a custom directory to install esp-idf (no spaces within the directory)
, but even though you have a choice for espressif, it must be left as the default C:\.espressif
3. If you have Comodo firewall and it pops up to ask if allow windows application or installer update, always select the latter (epically in the initial compiling stage).
DAVIDJOINER
Thanks medelec for your input
I have tried what worked for you but unfortunately does not solve the problem on my comuter
Have enclosed the message file after installing as you suggested
The clue must be in there somewhere but its beyond me
DAVID
DAVID
- test6.msg.txt
- (1.94 KiB) Downloaded 1032 times
Comparing with my installations, might be worth trying this ...
- Via Windows settings->Apps & Features, Un-install ESP-IDF tools, Git, Python
Use or create a Windows User with name with no spaces, (also try with Admin rights)
Re-install with esp-idf-tools-setup-2.3.exe (using suggested default options)- Install Python 3.7
Install Git 2.21.0
Download ESP-IDF, v4.1, to default directory (e.g. C:\Users\yourname\Desktop\esp-idf)
Install ESP-IDF tools to default (e.g. C:\Users\yourname\.espressif)
Select Additional Tasks (tick all)
- Set ESP to C:\Users\yourname\Desktop\esp-idf\
