STM32F401 UART
Has thanked: 109 times
Been thanked: 302 times
Re: STM32F401 UART
Try this ...
32F401RC.fcdx
(47.18 KiB) Downloaded 955 times
Alan_37
Has thanked: 57 times
Been thanked: 28 times
Re: STM32F401 UART
Post by Alan_37 »
Hi Leigh,
interrupt Still not triggering in software mode i put the FCD file in C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\ARM,
restart and recompile to chip .
Re: STM32F401 UART
Were you able to create interrupt icons for B7 (EXTI7 port B) and A3 (EXTI3 port A) and set the called macros, and compile ok?
Alan_37
Re: STM32F401 UART
Post by Alan_37 »
Hi , ohh ok i thought RX int , Yes now the interrupts are being triggered
but the data is not being recived properly , I send something and it reply
with something else
STM32F401_DUAL_UART.fcfx
(32.6 KiB) Downloaded 783 times
Re: STM32F401 UART
OK. You will need to remove the previous UART RX interrupt icons.
Alan_37
Re: STM32F401 UART
Post by Alan_37 »
Leigh , Ok working was my fault i set the interrupt on rising edge
Now software mode working Fine Thanks for your help
Regards Alan
Re: STM32F401 UART
Hi Alan,
I think I've replicated your hardware UART RX interrupt issue,
so I've made some changes to the UART RX interrupt code.
Please could you try this with your earlier UART RX interrupt test ...
32F401RC.fcdx
(47.03 KiB) Downloaded 892 times
If this works for you, the Matrix team can validate and update the official versions.
Alan_37
Re: STM32F401 UART
Post by Alan_37 »
Hi Leigh,
Sure will test tomorrow and let you know
Alan_37
Re: STM32F401 UART
Post by Alan_37 »
Hi Leigh,
I can confirm that the bug is now fixed 100%, have connected the RX of U1 and U2 together
so that the data arrives exactly the same time on the 2 UARTS.
Sent data every 200ms, tested for 20 minutes without any problems .
Kindly have a quick look to other STM Targets that maybe have same bug.
Thanks & well done !
Alan
