Hi Jorgen
Yes that helps.
The Flowcode component is only set to work with 0x0D, so any other ID will not work at all.
Hopefully I will have the 0x1E version by this weekend.
HMC5883L Bug or me!
- Has thanked: 724 times
- Been thanked: 783 times
Re: HMC5883L Bug or me!
Hi Jorgen.
I have had look into this in more detail.
If you search within the components ribbon for 5883 you will see 2 components.
QMC5883L and HMC5883L
The QMC5883 is if your ID Address is 0x0D & HMC5883L if your ID Address is 0x1E.
Can you make sure you have the hardware matches the correct Flowcode component first.
If not We can take it from there.
Just le me know the component name and what the ID address your hardware is showing.
I will be making a new QMC5883P component for Flowcode v11 as QMC5883P is the latest replacement.
- Has thanked: 839 times
- Been thanked: 205 times
Hi Martin!
I dobbelcheck with your i2C sniffer
GY-271 QMC5883L 0x1E This should be a newer model, should be better and more stable. The QMC5883L is not label on the pcb only GY-271. On the chip is label L5883 and according info I have found on the web the GY- 271 is the QMC5883L.
GY-273 HMC5883L 0x0D Older model. On this device I see the label HMC5883L on the pcb, but nothing on the chip
You wrote "I will be making a new QMC5883P component for Flowcode v11 as QMC5883P is the latest replacement", hopefully also for Flowcode 10 you have to think of all us poor FC10 user
Hope this make sense and can help you otherwice let me hear if I have misunderstood your question or anything I can do.
I can send you one of each if you want you can keep.
Br Jorgen
Br Jorgen
Hi Jorgen.
If you look at the datasheet for QMC5883L it shows:
The default I2C address is 0D: 0001101
The datasheet for HMC5883L shows:
I2C Address 7-bit address 0x1E
That is what I stated in my previous reply.
What I suggest is read the I2C address of your digital compass.
If it reads 0x0D then select the QMC5883L component.
If it reads 0x1E then select the HMC5883L component.
They are both available within Flowcode.
Sorry, it will only be available for Flowcode v11.
Hi again!
Thank´s Martin. again if I do something wrong or misunderstand something I apologize
From beginning I test with the HCM58833 doesn´t work, I tryed to switch over with the two devices none of them work, you made a new component where it was possible to switch between the two devices in properties, it also not work.
I have made a progam (Wiki modified)now where it is easy to switch between the two device, no matter which device I choose in the program it doesn´t work, and switch the devices. I have found a testprogram on the web with arduino IDE for both devices, they work. I want to use FC because I have to implement it in another FC project.
You can have a look in my testprogram if you want, and anyway I will not take more of your time so don´t waste more time on this I will found another soloution
Br Jorgen
Br Jorgen
- QMC_HMC_Wiki.fcfx
- (34.4 KiB) Downloaded 181 times
Hi Jorgen.
I just wanted to make sure you are using the correct Flowcode component for board.
Now that you have, I will do some testing and see what the issue is.
Hi Jorgen.
I just looked into HMC588L.
I believe your issue is having the LCD I2C speed set to 400KHz.
Can you try again with the LCD I2C speed set to 100KHz.
The only issue I can spot with the HMC588L component is the wrong return value.
This means if the component is ok then the return value would be something like 5, instead of 0.
I have fixed that issue.
To try the update.
Or
Place the attached component.
On hardware, I have tried the HMC588L and it is working me.
To try the update.
%ProgramData%\MatrixTSL\FlowcodeV10\ComponentsCode: Select all
%ProgramData%\MatrixTSL\FlowcodeV10\ComponentsIf Flowcode is already open, then you will need to reload your project for the new component to work
- HMC5883_Magnetometer.fcpx
- (7.05 KiB) Downloaded 185 times
Hi Martin!
Test with your new Component..
Sorry I can´t get it work? I have set the Baud to 100kHz for the display, try to switch the devices try display on same pin and seperate, taking new device, but no. After INIT I see lot of random number and then it stop. Work fine in IDE for both devices?
It is strange it work by you, is it my examble you use or your own, if your own, will you share so I can check?
Pls.
Jorgen
Pls.
Jorgen
