Component sfk 433 Mhz serial for Arduino, ext.
Has thanked: 707 times
Been thanked: 768 times
Re: Component sfk 433 Mhz serial for Arduino, ext.
Hi Jan.
I have found that if an interrupt enable is placed within another interrupt, it does indeed cause issues.
For example, it can restart all the code.
What I would do if I were you is to enable timer2 only once just below the enable INT0 enable icon .
Then just after the enable Timer2 icon, place a C code block with
cr_bit(PIE4,TMR2IE);
which stops the interrupt from firing.
Use that c code to replace all the timer2 disable icons.
Then I would replace all the timer2 enable icons with a c code block containing
st_bit(PIE4,TMR2IE);
jan.didden
Has thanked: 20 times
Been thanked: 12 times
Post by jan.didden »
Martin, thanks, I will see if I can get it to work that way.
I had a hunch that it had to do with (illegal?) overwrite of interrupt register contents, or possibly just a coding error in the register/bit name, but didn't know how to check that.
Martin mnfischer confirmed it indeed is an issue.
You have restarted me ;-)
Jan
Has thanked: 157 times
Been thanked: 911 times
Post by mnfisher »
Thanks Martin - a lot neater than my work round too I added a flag and restarted the timer on the main loop if not running.
Worked, but a bit clunky..
The interrupt rate given in the interrupt setup seems incorrect. By a factor of 4 - I had to set stated interrupt rate to 1/4 the desired rate.
Hi Jan/Martin
Sorry, there was a typo in my code and I have corrected it.
The correct codes are
and
The / should not have been present
I'm glad the information helped you to get restarted.
Thank you, Martin (mnfisher) for your great support to Jan and other members.
Your help is really appreciated by us all! :)
Post by mnfisher »
Thanks Martin,
That works perfectly. Not quite as straightforward as on the AVR chip but all's well etc...
This isn't quite the right topic so I'll post the code to the NEC IR topic...
jan.didden
Martin (medelec), just to be sure, your code enables/disables the timer but does not reset or clear it, correct?
Jan
Post by mnfisher »
It doesn't clear the timer (though for our/most purposes it doesn't matter)
jan.didden
I really would like to thank Martin mnfisher publicly for his support to get this project up and running.
I'm pretty sure he doesn't have loads of spare time but nevertheless always willing to listen and help.
There's a very long list of PM's between him and me.
I vote to give him a lifetime free FC update ;-)
Jan
Post by mnfisher »
And thanks to Jan & Martin (medelec) too..
If possible I'd like a lifetime supply of spare time - there seems to be a lot less of it about with every passing year...
Safak
Post by Safak »
Hi.
Can you share the latest version of the receiver and transmitter codes.
