ILI9488 not working in FC10
Has thanked: 914 times
Been thanked: 223 times
Re: ILI9488 not working in FC10
Post by jgu1 »
Hi Martin!
From start I have made the program in FC9 and everything work. Then I would continue in FC10 and then the display is blanck.
I just open my project in FC10 and compile and then I get this .c file
This .c file is from the FC10 compilation. I use the same ESP tool chain as in FC9: C:\Users\45505\.espressif. So do you mean I do something wrong? ;)
EDIT. Oh my god Martin, sorry in the rush it was the wrong file, so sorry, hereby the FC10 .c file :o
jorgen
NewSun.c
(194.23 KiB) Downloaded 220 times
Has thanked: 650 times
Been thanked: 856 times
Hi Jorgen,
Thanks for persisting with this one, I beleive I have found the problem. I wasn't getting it because I'm developing support for the newer 5.0 IDF which doesn't have my high speed IO optimisation.
Anyway single pin writes to PortB IO32 and above were being done to the lower PortA register. Looks like in adding 5.0 support I introduced the bug.
Fix should now be available via the library updates.
Post by jgu1 »
Hi Ben & Martin!
Your velcome Ben, always glad if I can help, anytime. :D
I just update the Lib´s and perform a test, working perfect now, really preciated, so now I can continue build my project in FC10, Thank´s. ;)
Br.
Jorgen.
