HB100 radar!
Has thanked: 778 times
Been thanked: 839 times
Re: HB100 radar!
jgu1 wrote:
Fri Sep 24, 2021 7:45 pm
ou know, two of those jumperwire (chinese) we use in breadboard when we connect devices, there was somtime bad connection in these
I don't doubt that at all, as I have a fully open circuit one in the past.
Nothing to be ashamed of.
Has thanked: 889 times
Been thanked: 216 times
Re: HB100 radar!
Post by jgu1 »
Hi Martin!
I have now perform some more test. I can tell you your program work. :D I have still a small issue with the amplifier, the signal is not 100% smoth so sometime I see a very high speed, but in between the correct speed. I have to let signal to pass a gate or similar connection.
I continue, you hear thank´s.
Jorgen
Re: HB100 radar!
Post by jgu1 »
Hi Martin!
Finally I got some more time to test. I have made the amplifier and have a nice clean sinal out to the input to the Pic.
I know your program work, anyway when I connect my generator to the input, I have same result in the display as you. But when I test with the radar connected, I see the speed in the display, but it is not stable and fluacting up and down if I walk speed between km/h 2 - 16, sometimes I feel I see the correct speed.
Honest, I don´t understand your program 100% (me the dummy :D ) But the signal which come in are not stable, should it the not be caltulate the average frequense in someway or?
I have Google the HB100 and found on youtube this https://www.youtube.com/watch?app=desktop&v=uSma0zQSnsU
I try to att. his project here but to big. It can downloaded here: https://www.dropbox.com/s/7d1fdzr8d243n ... 2.zip?dl=0 May be you can see if it is some similar to your program.
Of course I could use his program/project, but I will prefeer Flowcode.
If you not have time to look at it I understand, but dare to ask ayway ;)
Thank´s in advance.
Re: HB100 radar!
When the speed is wrong. can you note the speed ranges that are wrong?
The simple way around would be to set a minimum frequency rejection value.
The results could then be averaged out as you stated.
Thinking about it, if you can state a max speed range you want to detect, anything say 10MPH greater can be automatically rejected.
Re: HB100 radar!
Hi Jorgen,
See if the attached flowchart works any better?
It is untested.
I have limited the maximum frequency to 5000HZ which is approx. 159 mph.
That should stop a lot of the randomness.
I'm looking into improving ever further, by using a different method.
Doppler 16F1937 Test display v2.fcfx
(24.99 KiB) Downloaded 553 times
Re: HB100 radar!
Post by jgu1 »
Hi Martin!
Unfortunately it doesn´t help. I see the value in the display from 2 - 18 km/h sometimes I sense I see the correct speed. But it is difficult to see.
I have just orderd the PCB from Seedstudio, and then I will test this amplifier from the examble I send you.
The way I test, I take my testboard and walk direktion up against a wall. I am glad for your care and help, but again if you are busy then wait :D
Jorgen
Re: HB100 radar!
It might be worth comparing with the Arduino version as a temp thing.
Then you will know if the amp or the code?
Re: HB100 radar!
I have thought of an improvement.
It should work much better.
I will create the new version tomorrow.
If works, I will explain the difference.
Re: HB100 radar!
Post by jgu1 »
Wow Martin, Thank you. :D
Jorgen
Re: HB100 radar!
Hi, Jorgen.
It was not that easy to reject random frequencies.
Hopefully this one does.
This Flowchart measures two pulse widths 50ms between them and converts the results to a frequency.
If both are within 20Hz of each other a counter is incremented.
If both have a difference of more than 20Hz then a counter is decremented.
When the counter reaches 21 then the frequency is displayed.
This should be better than the bubble sort or averaging.
The issue with averaging is one rogue frequency will cause the total to still be out by a fair bit.
Hopefully my method won't.
The only thing is you will need to change from T1CKI (C0)pin to B0 pin.
Reason: Removed attachment & repaced with a better version. See below
