DS3231 ALARM
kaqkk007
- Has thanked: 4 times
- Been thanked: 4 times
Re: DS3231 ALARM
Just one question : do you plan to include the aging offset setting in the componens ? (a more inaccurate rtc will be released )
Re: DS3231 ALARM
Sim, preciso preciso desse rtc, para cronometrar as horas e salva los toda vez que tenho perca de energia
Vai ser lançado na versão 9?
Re: DS3231 ALARM
hi, why the alarm settings were not implemented on the DS3231 in the FC10 version? I tried to load the component made for the FC9 but FC10 does not see the new component loaded.
thanks
thanks
Re: DS3231 ALARM
I put the fcpx file I found here into the library but when I want to use it there is no option for pin settings so I tried to use it with the "old" rtc, but the 2 separate rtcs don't like each other. How can I read and write a register in the rtc? osc enable aging offset. Pic 18f252 ...
