Populating MySQL database function.
RGV250
Has thanked: 46 times
Been thanked: 48 times
Re: Populating MySQL database function.
Post by RGV250 »
To start with it will only be one message every 5 seconds or so but later may end up with 15 so still only 3 / sec average.
Bob
Has thanked: 110 times
Been thanked: 302 times
Just to add another piece to the jigsaw puzzle and good work from chipfryer27
Here's a demo of the capabilities of GNU/Linux and Flowcode.
This script will install mysql and create a demo database and table.
Edit the user 'leigh' to your login account and download it to your Raspberry Pi.
In the terminal (or putty, ssh), make the file executable (chmod 777 setup_db.txt) and run it (./setup_db.txt)
setup_db.txt
(389 Bytes) Downloaded 654 times
Similarly, this script can be used to test the DB and data insert.
insert_db.txt
(148 Bytes) Downloaded 614 times
And here is a demo Flowcode project that records temperature measurements to the test DB.
RPI_SHT21_DB.fcfx
(10.85 KiB) Downloaded 701 times
Hope it helps, at least it will get you started with SQL statements. :D
Has thanked: 478 times
Been thanked: 713 times
Hi Leigh
Thanks for the above.
I'm creating a little guide regarding this and Bob is helping proof read. It will show how to create a DB and tables, then the steps to create a script that will update tables etc. Then a Flowcode example that updates.
Interesting to see your use of script, different to mine but then you are after all a Guru :D
RGV250
Post by RGV250 »
Hi Martin,
Apologies for not replying earlier, I will have a play with your example later, I have been spending a lot of time with the example from Chipfryer and the brain cell cannot handle more than one thing at a time.
Bob
RGV250
Post by RGV250 »
I should have mentioned Leigh in the post above, I was thinking of Martin in a different post :oops: :oops: :oops:
I have just managed to modify chipfryers example to run on a Raspberry Pi from the other post and simulate it with everything on the same PC so this will come in very handy when I test it out on the actual Raspberry Pi hardware.
Bob
I updated the guideviewtopic.php?f=3&t=2248 to include latest MySql and PHP.
