Thank you very much chipfryer27 for your last response.
I completely forgot to disable WDT.
Once disabled on both the master and slave, Proteus now works correctly according to the FC files:
- The Tx pin no longer permanently sends the "FE" value.
- The times programmed in FC are met correctly in Proteus
- The master reads his keyboard well and sends the corresponding commands.
- The slave receives, interprets and correctly executes what is sent by the master.
The next step will be that when the slave receives a request from the master, it reads its own keyboard and the value of the pressed key is sent to the master.
But that will be starting next Tuesday, now it's a few days of holydays.
Once again I reiterate my gratitude for your responses.
RS485 example
Carmelo
- Has thanked: 57 times
- Been thanked: 4 times
- Has thanked: 478 times
- Been thanked: 713 times
Re: RS485 example
Glad to hear you have it working and happy to have been of help.
Have a good holiday.
Me alegra saber que lo tienes funcionando y feliz de haber sido de ayuda.
Ten unas buenas vacaciones.
