SSD1306 I2C with Pic16f1937!
Has thanked: 177 times
Been thanked: 1022 times
Re: SSD1306 I2C with Pic16f1937!
Post by mnfisher »
Jorgen's example tweaked to use rows instead of y co-ordinates.
Still trying to shake the image of Iain in the 'pink'... Don't have nightmares (or sunburn)
Martins SSD1306 Component Test.fcfx
(14.28 KiB) Downloaded 269 times
Has thanked: 889 times
Been thanked: 216 times
Post by jgu1 »
Martin the last .FCPX doesnt work, again spaceproblem, so I went back :)
Post by mnfisher »
Which demo did you try - yours has quite a few strings..
Post by mnfisher »
The Flowcode component was back. Very odd. Deleted again.
It's all very odd - gone back to only working at 100kHz and then only for a brief while. Gremlins? Rod Serling is sitting in the corner and something very odd is about to occur?
Then - I found and swapped to a 64 pixel display. One of the jumpers 'failed'. (Should have build Iain's 'jumper tester')
The 64 pixel display needs 'interlaced' - so added that. Mines also needs inverted set to true (in the FC component - what I have as 'inverted' is 'if 1' (so always))
Still locking up at 400kHz - I might go for a little lie down in a dark place...
So - working a (rather dim) 64 * 128 pixel display with 8 rows of text too..
Try this:
SSD1306_Min.fcpx
(4.78 KiB) Downloaded 275 times
Post by mnfisher »
Just tested on an esp32 - i2c running at 1MHz works okay so not sure why Uno is only working at 100kHz :-(
Post by jgu1 »
The last one doesn´t work correctly. Very small font x and y doesn´t work. Martin I use the first you made, this work for me ;)
Jorgen
SSD1306_Min.fcpx
(4.34 KiB) Downloaded 267 times
Post by mnfisher »
Check the value of interlaced (new property) - off for 32 pixel display on for 64...
y is now row 0..3 (or 0..7)
Post by jgu1 »
No change, no matter what setting I use in the config?
I will use the one which working :)
Jorgen
Post by mnfisher »
🙄 Would like to get you up and running with the VU meter too..
Maybe revisit it later..
