"sleep" inside a loop
Has thanked: 156 times
Been thanked: 904 times
Re: "sleep" inside a loop
Post by mnfisher »
Power consumption - I'm intrigued how you got it so low...
So using a PIC12F1840 as per original question - I connected a (sensitive) ammeter. I set the code to use sleep (as above) with a 4s (0b1100) WDT timeout - and pulsed a4 for 1ms (again using a WDT with a prescaler of 0)
When a4 not pulsed - I set to an input.
I set the clock to 31KHz (LF IntOsc) and also in 'Sleep' do:
VREGCONbits.VREGPM = 1;
CLRWDT();
SLEEP();
At 2.2V supply - I get a current draw of (average) 4.80mA - with a 'peak' of 4.85mA when the pulse is sent.
Below ~2V it fails to run (constantly restarting?) and at 5V - it's using 10.53mA.
These figures seem a bit 'high' (the PIC boasts nanoWatt technology?) - and I maybe should unplug the PicKit when testing?
I also tested using the standard 'clock' and a delay - and the results aren't dramatically different for example at 5V with 1s on / 1s off at 16MHz I get ~11.7mA (clock etc is correct as I get a nice 1s blinkie on the scope)
So - maybe my measurement technique is 'off' - I'd certainly hoped to see better savings using sleep... Testing 'sleep' (using a 256s WDT timeout and 1ms pulse averages 10.48mA at 5V :-( )
Post by mnfisher »
Looks like unplugging the PicKit is key...
Unplugged I get 12.56uA at 2V when in sleep mode... And it is still working at 1.8V :-) (Not quite at the 300nA in the datasheet though?)
Just rewired and tidied - and seem to be in the right ballpark for sleep ~300nA and with nothing attached to the MCU apart from the power supply.
Has thanked: 429 times
Been thanked: 647 times
Hi Martin
You seem currently drawn in and it will soon consume your time if not energy.... :)
ELECTRONICA67
Has thanked: 30 times
Been thanked: 9 times
Post by ELECTRONICA67 »
Hello :)
It's an interesting topic that I think will be useful in some project sooner or later. It's taken me a few weeks, but I still think it's worth learning, and I think there's more to learn; but as Lain says, it takes time. . . ;)
Best Regards
