ESP32 Compiling error
jollybv
Has thanked: 42 times
Been thanked: 15 times
Re: ESP32 Compiling error
Post by jollybv »
Hi Guys
for some reason I'm unable to compile to the chip i have tried in V7 and V9 same problem I've tried using MPLAB 5.50 and just downloaded MPLAB 6 both give me the same error (Illegal command line parameter T) have no clue what to do to rectify this.
Compile error.txt
(7.36 KiB) Downloaded 590 times
Has thanked: 772 times
Been thanked: 831 times
Hi Brian.
I am wondering if it's a path issue.
Could you place the project files in an unprotected directory e.g Documents folder, and try there?
Has thanked: 107 times
Been thanked: 302 times
Have you chosen the correct programmer setting in "Compiler Options"?
Looks like you are trying to use PICkit3 to program the 18LF46K80 device?
jollybv
Post by jollybv »
Hi Leigh
This is really strange as i have been using these settings for years and it worked. I have not been working with pic for a while been playing with the ESP32 so not sure when this problem started.
The compiler settings are as follows
Location
$(fcddir)PIC\batch\pic_xc8_comp.bat
Parameters
"$(compilerpic)" $(chip) "$(outdir)" "$(target)"
If i compile to hex it complies and yes i am using a PIC18LF46K80 and a pickit3 programmer. I have checked in MPLABX and the programmer is working and can read the chip on the board
What i have noticed is that in program options there is no program ports which is strange as i can read the programmer in MPLABX
Program options.JPG (69.23 KiB) Viewed 9149 times
kersing
Has thanked: 81 times
Been thanked: 65 times
Post by kersing »
Iirc mplabx and the command line programmer require different firmware in the pickit, however you are not getting to that point yet.
Looking at the output the settings for the programmer are wrong for this version of the MPLA’s software. What are the settings in FC for the programmer? (Not compiler or linker)
Has thanked: 177 times
Been thanked: 1016 times
Post by mnfisher »
It's an expensive fix but pickitplus (https://www.pickitplus.co.uk/Typesetter/) is very good...
kersing
Post by kersing »
Using different software won’t solve the issue of the wrong arguments being supplied to the software. (It will require different arguments requiring changes to the settings anyway so why not fix them for the current tool)
jollybv
Post by jollybv »
The Programmer settings are as follows
Location
C:\Program Files\Microchip\MPLABX\v6.00\mplab_platform\mplab_ipe\pk3cmd.exe
Parameters
/P$(chip) /F"$(outdir)$(target).hex" /TPPK3 /M /OL
kersing
Post by kersing »
The /TPPK3 is what causes the error. You can try removing it.
jollybv
Post by jollybv »
That worked but I'm really baffled as I have used those settings for years
anyway its working again thanks for your help.
