I installed FC10, and it fails at exactly the same spot as FC9.
I will now make a complete new project, just a simple calculation, and see what that does.
Jan
ST7789 display
jandidden
- Has thanked: 28 times
- Been thanked: 12 times
- Has thanked: 153 times
- Been thanked: 865 times
Re: ST7789 display
Can you post the complete output (as an attachment) - so we can see where the failure point is..
I see from the snippet - it's v4.4 of the esp-idf and Python 3.8 - so maybe the reinstall hasn't worked it's magic??
Re: ST7789 display
What do you know: in FC10, with a simple one-icon program (setting a variable to 2), it fails at exactly the same point ...
I'll try to do a complete re-install of all things EDF next.
De-install, delete all left over folders.
Jan
Jan
Re: ST7789 display
Martin,
With the new install, ESP says there's no python on the system.
Reason must be that it was not added to the environment.
I noticed in your description you had to tick a box to add that, but in my install (from the link you provided) the process does not show me that option.
Is there a way to manually add python to the environment?
Jan
Jan
Re: ST7789 display
Tried adding python environment to system manually, no joy, EDF still can't fine it.
What a mess.
Jan
What a mess.
Jan
Re: ST7789 display
Got that sorted, progress - got another failure!
FAILED: build.ninja
FAILED: build.ninja
-- Components: app_trace app_update bootloader bootloader_support bt cmock console cxx driver efuse esp-tls esp_adc esp_app_format esp_common esp_eth esp_event esp_gdbstub esp_hid esp_http_client esp_http_server esp_https_ota esp_https_server esp_hw_support esp_lcd esp_local_ctrl esp_netif esp_partition esp_phy esp_pm esp_psram esp_ringbuf esp_rom esp_system esp_timer esp_wifi espcoredump esptool_py fatfs freertos hal heap http_parser idf_test ieee802154 json log lwip main mbedtls mqtt newlib nvs_flash openthread partition_table perfmon protobuf-c protocomm pthread sdmmc soc spi_flash spiffs tcp_transport ulp unity usb vfs wear_levelling wifi_provisioning wpa_supplicant xtensa
-- Component paths: C:/Espressif/frameworks/esp-idf-v5.0.1/components/app_trace C:/Espressif/frameworks/esp-idf-v5.0.1/components/app_update C:/Espressif/frameworks/esp-idf-v5.0.1/components/bootloader C:/Espressif/frameworks/esp-idf-v5.0.1/components/bootloader_support C:/Espressif/frameworks/esp-idf-v5.0.1/components/bt C:/Espressif/frameworks/esp-idf-v5.0.1/components/cmock C:/Espressif/frameworks/esp-idf-v5.0.1/components/console C:/Espressif/frameworks/esp-idf-v5.0.1/components/cxx C:/Espressif/frameworks/esp-idf-v5.0.1/components/driver C:/Espressif/frameworks/esp-idf-v5.0.1/components/efuse C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp-tls C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_adc C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_app_format C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_common C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_eth C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_event C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_gdbstub C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_hid C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_http_client C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_http_server C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_https_ota C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_https_server C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_hw_support C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_lcd C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_local_ctrl C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_netif C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_partition C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_phy C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_pm C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_psram C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_ringbuf C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_rom C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_system C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_timer C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_wifi C:/Espressif/frameworks/esp-idf-v5.0.1/components/espcoredump C:/Espressif/frameworks/esp-idf-v5.0.1/components/esptool_py C:/Espressif/frameworks/esp-idf-v5.0.1/components/fatfs C:/Espressif/frameworks/esp-idf-v5.0.1/components/freertos C:/Espressif/frameworks/esp-idf-v5.0.1/components/hal C:/Espressif/frameworks/esp-idf-v5.0.1/components/heap C:/Espressif/frameworks/esp-idf-v5.0.1/components/http_parser C:/Espressif/frameworks/esp-idf-v5.0.1/components/idf_test C:/Espressif/frameworks/esp-idf-v5.0.1/components/ieee802154 C:/Espressif/frameworks/esp-idf-v5.0.1/components/json C:/Espressif/frameworks/esp-idf-v5.0.1/components/log C:/Espressif/frameworks/esp-idf-v5.0.1/components/lwip C:/Users/jandi/fc10_test/main C:/Espressif/frameworks/esp-idf-v5.0.1/components/mbedtls C:/Espressif/frameworks/esp-idf-v5.0.1/components/mqtt C:/Espressif/frameworks/esp-idf-v5.0.1/components/newlib C:/Espressif/frameworks/esp-idf-v5.0.1/components/nvs_flash C:/Espressif/frameworks/esp-idf-v5.0.1/components/openthread C:/Espressif/frameworks/esp-idf-v5.0.1/components/partition_table C:/Espressif/frameworks/esp-idf-v5.0.1/components/perfmon C:/Espressif/frameworks/esp-idf-v5.0.1/components/protobuf-c C:/Espressif/frameworks/esp-idf-v5.0.1/components/protocomm C:/Espressif/frameworks/esp-idf-v5.0.1/components/pthread C:/Espressif/frameworks/esp-idf-v5.0.1/components/sdmmc C:/Espressif/frameworks/esp-idf-v5.0.1/components/soc C:/Espressif/frameworks/esp-idf-v5.0.1/components/spi_flash C:/Espressif/frameworks/esp-idf-v5.0.1/components/spiffs C:/Espressif/frameworks/esp-idf-v5.0.1/components/tcp_transport C:/Espressif/frameworks/esp-idf-v5.0.1/components/ulp C:/Espressif/frameworks/esp-idf-v5.0.1/components/unity C:/Espressif/frameworks/esp-idf-v5.0.1/components/usb C:/Espressif/frameworks/esp-idf-v5.0.1/components/vfs C:/Espressif/frameworks/esp-idf-v5.0.1/components/wear_levelling C:/Espressif/frameworks/esp-idf-v5.0.1/components/wifi_provisioning C:/Espressif/frameworks/esp-idf-v5.0.1/components/wpa_supplicant C:/Espressif/frameworks/esp-idf-v5.0.1/components/xtensa
-- Configuring incomplete, errors occurred!
See also "C:/Users/jandi/fc10_test/build/CMakeFiles/CMakeOutput.log".
FAILED: build.ninja
C:\Espressif\tools\cmake\3.24.0\bin\cmake.exe --regenerate-during-build -SC:\Users\jandi\fc10_test -BC:\Users\jandi\fc10_test\build
ninja: error: rebuilding 'build.ninja': subcommand failed
ninja failed with exit code 1, output of the command is in the c:\users\jandi\fc10_test\build\log\idf_py_stderr_output_3540 and c:\users\jandi\fc10_test\build\log\idf_py_stdout_output_3540
Build Failed
Re: ST7789 display
Here's the output log if its any use.
[0/1] Re-running CMake...
-- ccache will be used for faster recompilation
-- Project is not inside a git repository, or git repository has no commits; will not use 'git describe' to determine PROJECT_VER.
-- Building ESP-IDF components for target esp32
-- Project sdkconfig file C:/Users/jandi/fc10_test/sdkconfig
-- Found Python3: C:/Espressif/python_env/idf5.0_py3.11_env/Scripts/python.exe (found version "3.11.2") found components: Interpreter
-- App "esp-project" version: 1
-- Adding linker script C:/Users/jandi/fc10_test/build/esp-idf/esp_system/ld/memory.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_system/ld/esp32/sections.ld.in
-- Adding linker script C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_rom/esp32/ld/esp32.rom.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_rom/esp32/ld/esp32.rom.api.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_rom/esp32/ld/esp32.rom.libgcc.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_rom/esp32/ld/esp32.rom.newlib-data.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_rom/esp32/ld/esp32.rom.syscalls.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_rom/esp32/ld/esp32.rom.newlib-funcs.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v5.0.1/components/soc/esp32/ld/esp32.peripherals.ld
FAILED: build.ninja
C:\Espressif\tools\cmake\3.24.0\bin\cmake.exe --regenerate-during-build -SC:\Users\jandi\fc10_test -BC:\Users\jandi\fc10_test\buildRe: ST7789 display
I think I need to take a step back.
FC9, FC10, different projects, different directories/paths, it always fails somewhere.
There must be some underlying issue that no matter what I do, there's always a failure.
There must be something I'm overlooking.
Edit: OTOH, both FC9 and FC10 work fine with the PIC toolchain. So it must be something in the ESP toolchain.
Jan
Jan
- Has thanked: 411 times
- Been thanked: 635 times
Re: ST7789 display
I've been following the recent ESP posts especially with regards to FC v10 / ESP v5 and the problems people are having. To say information is fragmented is a bit of an understatement.
On my W8.1 machine I run every version of FC from v5 and in v9 I installed the ESP toolchain exactly as documented in the guide available on the website. It worked first time and after I installed v10 it still worked. On this machine I've had no issue in using the compatible ESP's listed.
I have a W10 machine and I only have FC v10 installed on it. When I attempted the ESP toolchain install I did run into a problem or two, but I put that down to me not paying attention during the install. I uninstalled everything, restarted the machine and ran a registry cleaner. I then started the install again and it worked fine.
Keen to try ESP v5, a few weeks back I thought to install it on my W10 machine and tried to do so following the numerous forum posts. However none worked for me so I left it alone as there wasn't any urgency in getting it working and my W8.1 still works.
After reading Martin's post on Sunday (3:31pm) in which he kindly documented the steps he took to get things running, I tried again today.
Firstly though I uninstalled all existing Python, GIT and ESP installs (manually deleting folders where necessary), rebooted and ran a registry cleaner. I then followed Martin's instructions, running each download in turn as "administrator". Note that one of the downloads did inform that the version would not work on any release previous to W10, but I can't remember which.
I am very pleased to inform that my W10 machine now compiles using ESP v5. Huge thanks to Martin for taking the time to document his process and posting.
For those that are still struggling, perhaps try uninstalling everything, running a registry cleaner and then running the downloads as "administrator"?
I'm running:-
W10 Pro
FC v10.0.3.24 (earlier should work fine too)
Python 3.11.3
GIT 2.40.1
Espressif-IDE 2.9.1 with ESP-IDF v5.0.1
When compiling to chip, I didn't need to push the on-board button on the module to download the code as in previous ESP version, it downloaded all by itself
Again, a big thank you to Martin (or should that be Rembrandt
I'm running:-
W10 Pro
Python 3.11.3
GIT 2.40.1
