Combine parameters in decisions
MJU20
Has thanked: 101 times
Been thanked: 70 times
Post by MJU20 »
I want to combine parameters in one decision.
I think I did this in the past but suddenly I don't get it to work.
Example:
I want to check a variable against a previous value.
The new value is Temp and the old value is TempOld.
If the new value is 4°C higher OR 4°C lower then the old value, the value must be rejected with a decision.
How do I combine the > and < in 1 line in a decision?
This is how I did it, but it doesn't work.
Temp < (TempOld - 4) OR Temp > (TempOld + 4)
Has thanked: 646 times
Been thanked: 704 times
Re: Combine parameters in decisions
The issue is OR is bitwise, which is not what you are after.
Take a look at this post as it should help.
MJU20
Post by MJU20 »
Oh my!!
This is right!
Thank you Medelec35..
You're welcome, as that can catch a lot of people out.
MJU20
Post by MJU20 »
Strange:
Temp < (TempOld - 4) || Temp > (TempOld + 4)
Did not work...
I have just read your example again and you will need
Temp <= (TempOld - 4) || Temp >= (TempOld + 4)
Without the
it will be 5 or more.
Is that the issue you have?
Note: it is good practice to have each equation enclosed within brackets so you could try
(Temp <= (TempOld - 4))|| (Temp >= (TempOld + 4))
MJU20
Post by MJU20 »
Thanks again medelec35.
But this confuses me more and more.
I've used combined variables often in Flowcode, but these days all my attempts fail.
Later in the chart I want to check if a temperature is the same as the previous value AND if a counter (byte) isn't larger then a certain value.
But again, this must be my lack of intelligence, but this doesn't work either.
Is it because I combine a float (temp/tempold) with a byte variable (counter)?
((Temp != TempOld) && (counter != 2))
So this should read: If NOT Temp is the same as TempOld AND counter is not 2.. then...
The way I read it, the first part, if that is true (so they are not the same) this part is true
AND this with the second part: if counter is not 2, then this is also true.
So this should be inverse to this (in my case couter is reset to 0 everytime):
((Temp == TempOld) && (counter > 2))
I think I must write it all down somewhat more, I'm getting old :)
Has thanked: 84 times
Been thanked: 265 times
From your description, I think you need
 ((Temp == TempOld) && (counter < 2))
Has thanked: 214 times
Been thanked: 362 times
(Leigh beat me to it, but here's my answer anyway...)
MJU20 wrote:
Tue Jan 11, 2022 5:42 pm
This would be:
if ((Temp == TempOld) && (counter <= value))
The two expressions in the inner brackets are evaluated separately, so they won't 'interfere' with each other.
However, the problem could be the comparison between float values. For example, 5.000000001 does not equal 5.000000000, but you might want your program to treat them as equal.
One way to check if floating point values are equal is to subtract them from each other and check that the result is close to zero. Something like this would be true if the values 'float1' and 'float2' are close enough to consider them as the same value:
if (fabs(float1 - float2) < 0.000001)
"fabs" is a function that ensures the parameter is positive, e.g. fabs(-0.3) = 0.3
The value "0.000001" is often called "epsilon" and needs to be set to a value specific to your program - i.e. it depends how close the values need to be to be seen as the same, and this depends on the accuracy of your measurements, their expected ranges and perhaps any other sources of error in your measurements.
The attached program shows this in Flowcode.
floating point comparison.fcfx
(7.91 KiB) Downloaded 486 times
