Lost with compile error
alanwms
Has thanked: 26 times
Been thanked: 8 times
Post by alanwms »
IS there a chance you can look at the list of errors and help me figure out what I did wrong?
p.erasmus
Has thanked: 104 times
Been thanked: 88 times
Re: Lost with compile error
Post by p.erasmus »
Hi ,
It seems all the errors has to do with the UART and string handling functions,
I would first comment the UART and all string macro's out to see what happens
Has thanked: 724 times
Been thanked: 783 times
Hi Alan.
The issue is with
Closed_loop_PWM2
user macro.
On the yes branch of
AN1_current_HP > PWM2_Current_Target OR AN1_current_HP = PWM1_Current_Target
the is an undefined Goto Connection point.
I'm guessing it was set for some other connection point e.g B, but that has been deleted?
That would cause this issue.
The no branch also makes the code continue to the end, so the decision branch is redundant.
It can be removed or disabled unless you have just posted a cut down version?
alanwms
Post by alanwms »
You the man! Thanks.
For future reference how the error could be found.
1. Make sure you don't have the word error within the project title, so rename.
2. Compile to hex.
3. Either open project Name.msg.txt
or
select Build ribbon, Compiler messages.
Select a blank area within compiler messages text, hold ctrl and press a to select all, then ctrl c to copy (or use the right mouse button)
Run notepad or any text viewer, use ctrl v (or right-click mouse button) and paste within text viewer.
4. Left-click anywhere at the top of the text editor and search (normally ctrl f) for the word error.
In this case, you should see:
Error found.png (4.6 KiB) Viewed 8709 times
That tells you to look for a label (a goto) within FCM (FlowCode user Macro) Closed_loop_PWM2_B
alanwms
Post by alanwms »
Thank you Martin - I did catch the PCC_Closed_loop_pwm2_B, but could not figure out where the "B" came from. I though that was the full name but apparently, it was a goto indicator.
Glad you put this down for me. I was going to ask how I can find this stuff, but felt a little pushy!
I compiled another program with a goto (with nowhere to go to), and went through the steps above - Worked great
Thanks again
Has thanked: 616 times
Been thanked: 815 times
Regarding this line of code.
This will be doing a binary OR and not a boolean comparison OR which is I beleive is what you are after.
Try this instead.
(AN1_current_HP > PWM2_Current_Target) || (AN1_current_HP = PWM1_Current_Target)
alanwms
Post by alanwms »
Thanks Ben - Not sure of the difference here. Are you pointing out the parentheses? or are you pointing to a difference betweed "or" and "||"
Hi Alan.
The parentheses makes sure that calculations or conditions are completed in the correct order.
Using
instead of
 OR
is vital for the condition to work, so that is the main point.
alanwms
Post by alanwms »
Thank you!
