FLOWCODE 9 - ARDUINO BL0127-1
ctksfc
Has thanked: 3 times
Been thanked: 2 times
Post by ctksfc »
URGENT
We are desperately trying to get the Actuators board working with BL0371 - we have tried the Demo Flowcode on you website BIT it is NOT compiling to chip (Arduino Uno R3 PDIP) ;
Target folder: H:\Flowcode
Source name:   \\college.ctksfc.local\ict\StaffHomeFolders\j.teigland\BTECNats\Unit 6\BL0127 - Actuators\BL0127 - Actuators\Arduino\BL0127 Actuators Demo Flowcode9.fcfx
Title:
Description:
Device:        ARD.ATMEGA.ATMEGA328P
Generated by:  Flowcode v9.2.0.33
Date:          Wednesday, May 04, 2022 08:29:52
Users:         50
Registered to: ctksfc (98801268)
Licence key: E7JRY1
   NOT FOR COMMERCIAL USE
https://www.flowcode.co.uk
Launching the compiler...
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\AVR\batchfiles\avra.bat  "C:\Program Files (x86)\Flowcode\Compilers\avrv5\" atmega328p "H:\Flowcode\BL0127 Actuators Demo Flowcode9.elf" "H:\Flowcode\BL0127 Actuators Demo Flowcode9.c" "H:\Flowcode\BL0127 Actuators Demo Flowcode9.lst"
H:\Flowcode>REM CRC: EA277D0C7EF9B4E537B79187D0BE7A25FA6080B4B01BE48BAF713429E4B690411241251B4A05C2B5828F4452C9F7348705C640EF477B79E0C7881D2E5EEC9BD6FE0D8D4660AC0314F98C28BCA92AF856EFD1DB5B777140BC4D00059D7958998291880A09BBE74CF7BA3F4E37F13004EE3637760F1F0B7DA0CC623CD30E3C7D6BAB4C3FE6151D92B8EC0ADD55E96639DAC02472BDE3806EF43AE3A028BD32A5DAE68BB191DA97CB6883A66D3C41849952BB2DD264AF32733E2C3050DA273BE4EEFF12703F3DAF67B119A5A5B069403B38249A6C4D8A1304B09A437E7E2D43FD26DF891DB3086C82D6
H:\Flowcode>REM REVISION: 1.0
H:\Flowcode>REM GUID: EA0828B2-5C70-41A5-8C54-F359DD5CC88B
H:\Flowcode>REM DATE: 29\03\2021
H:\Flowcode>REM DIR: FCD\AVR\batchfiles\avra.bat
H:\Flowcode>"C:\Program Files (x86)\Flowcode\Compilers\avrv5\bin\avr-gcc.exe" -mmcu=atmega328p -Os -ffunction-sections -fdata-sections -funsigned-char -o "H:\Flowcode\BL0127 Actuators Demo Flowcode9.elf" "H:\Flowcode\BL0127 Actuators Demo Flowcode9.c" -lm -Wl,-gc-sections
In file included from C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\includes.c:814:0,
                 from H:\Flowcode\BL0127 Actuators Demo Flowcode9.c:547:
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\AVR\AVR_CAL_PWM.c:110:5: warning: #warning "PWM Channel Uses Resource Timer 0" [-Wcpp]
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\AVR\AVR_CAL_PWM.c:495:3: warning: #warning "Period control register not available on target device, period will default to 255 + 1" [-Wcpp]
In file included from C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\AVR\AVR_CAL_IO.c:43:0,
                 from C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\internals.c:431,
                 from H:\Flowcode\BL0127 Actuators Demo Flowcode9.c:45:
H:\Flowcode\BL0127 Actuators Demo Flowcode9.c: In function 'FCD_05261_switch_base__ReadState':
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\AVR\AVR_CAL_IO.h:64:65: error: 'FCP_PIN_A' undeclared (first use in this function)
 #define FCP_GET_B(Port, Mask, Shift)   (FC_CAL_Port_In_DDR__x((&FCP_PIN##Port), (&FCP_TRIS##Port), (Mask), (Shift)))
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\AVR\AVR_CAL_IO.h:61:42: note: in expansion of macro 'FCP_GET_B'
 #define FCP_GET(Type, Port, Mask, Shift) FCP_GET_##Type(_##Port, Mask, Shift)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\AVR\AVR_CAL_IO.h:48:31: note: in expansion of macro 'FCP_GET'
 #define GET_PORT_PIN(p,b)     FCP_GET(B,p,(1<<b),b)
H:\Flowcode\BL0127 Actuators Demo Flowcode9.c:571:12: note: in expansion of macro 'GET_PORT_PIN'
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\AVR\AVR_CAL_IO.h:64:65: note: each undeclared identifier is reported only once for each function it appears in
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\AVR\AVR_CAL_IO.h:64:83: error: 'FCP_TRIS_A' undeclared (first use in this function)
H:\Flowcode\BL0127 Actuators Demo Flowcode9.c: In function 'FCD_05261_switch_base__WaitUntilHigh':
H:\Flowcode\BL0127 Actuators Demo Flowcode9.c:624:20: note: in expansion of macro 'GET_PORT_PIN'
    #if (0) // 0 == 1
    #if (0) // 0 == 1
H:\Flowcode\BL0127 Actuators Demo Flowcode9.c: In function 'FCD_05261_switch_base__WaitUntilLow':
H:\Flowcode\BL0127 Actuators Demo Flowcode9.c:675:20: note: in expansion of macro 'GET_PORT_PIN'
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\AVR\batchfiles\avra.bat reported error code 0x1
Autoclose turned off
FINISHED
Has thanked: 523 times
Been thanked: 709 times
Re: FLOWCODE 9 - ARDUINO BL0127-1
It looks like you have a switch component that has a pin connection set to use PortA which doesn't exist on the Arduino device.
If you attach the project file then I can take a look for you.
ctksfc
Post by ctksfc »
Thank you as mentioned the Sample is taken from your website here- NOT modified ;
https://www.matrixtsl.com/webshop/e-blo ... board.html
We have tried BOTH FC8 and FC9 in combination with same errors
BL0127 Actuators Demo Flowcode 7-8.fcfx
(21.09 KiB) Downloaded 603 times
(25.72 KiB) Downloaded 599 times
ctksfc
Post by ctksfc »
So Yes the switch was the issue - set if for C0 (BL0114 on Ports A/D) have so far managed to get Servo and DC Motor running - can you please advice Pin Settings for Stepper motor (Pins D8-D13) - thanks in advance (this in FC8) (FC9 only ServoMotor working)
Has thanked: 662 times
Been thanked: 725 times
Can you try the attached flowchart, please?
If it works OK, then the current example will be updated.
(25.61 KiB) Downloaded 607 times
ctksfc
Post by ctksfc »
I've Cracked it for FC8 - will post results later
ctksfc
Post by ctksfc »
Thanks Martin - YES that is now working with ALL 3 actuators
Nur_khan
Post by Nur_khan »
Hi Martin ,
Having issue transferring the code to the BL0371 board
Could you pls help ... see message below
Target folder: C:\Users\Owner\Downloads
Source name:   C:\Users\Owner\Downloads\BL0127 Actuators Demo Flowcode9.fcfx
Title:
Description:
Date:          Thursday, May 12, 2022 13:34:15
Users:         50
Registered to: nur_khan (93752989)
Licence key: 33QGBX
Compilation is up-to-date
Linking is up-to-date
Using FCD settings for programmer
Launching the programmer...
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\AVR\batchfiles\avrc_arduinoA.bat  "C:\Program Files (x86)\Flowcode\Common\Compilers\avrv5\" m328p arduino  115200 "C:\Users\Owner\Downloads\BL0127 Actuators Demo Flowcode9.hex"
C:\Users\Owner\Downloads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
C:\Users\Owner\Downloads>REM REVISION: 1.0
C:\Users\Owner\Downloads>REM GUID: BC89C337-8FBB-43B7-A3A7-C7902C121931
C:\Users\Owner\Downloads>REM DATE: 29\03\2021
C:\Users\Owner\Downloads>REM DIR: FCD\AVR\batchfiles\avrc_arduinoA.bat
C:\Users\Owner\Downloads>"C:\Program Files (x86)\Flowcode\Common\Compilers\avrv5\bin\avrdude.exe" -pm328p -P115200 -b"C:\Users\Owner\Downloads\BL0127 Actuators Demo Flowcode9.hex" -carduino -D -Uflash:w:""
avrdude.exe: invalid baud rate specified 'C:\Users\Owner\Downloads\BL0127 Actuators Demo Flowcode9.hex'
Error returned from [avrdude]
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\AVR\batchfiles\avrc_arduinoA.bat reported error code 0x1
FINISHED
I have moved the compiler messages within the code tags as it looks better and takes up less room.
The issue being
This normally happens when you have not selected the correct com port for your Arduino.
With the Arduino connected to USB, select Build, Project Options.
On the lower right below the Programmer port, select the correct com port for your Arduino.
Don't leave it showing n/a.
Just a thought.
A simular issue can occur if there is a comms issue between the Arduino and the PC
